35
Something I feel I ought to know for sure: if I ls <something>, will rm <something> remove exactly the same files that ls displayed? Are there any circumstances where rm could remove files that ls did not show? (This is in the 18.04 bash)
Edit: thank you to everyone who answered. I think the full answer is a combination of all the answers, so I have accepted the most up-voted answer as "the answer".
Unexpected things I have learned along the way:
  • ls is not as straightforward as you might think in its handling of its arguments
  • In a simple un-fiddled-with installation of Ubuntu, .bashrc aliases ls
  • Don't name your files beginning with a dash as they can look like command arguments, and naming one -r is asking for it!
B.Tanner
  • 2,685
10 Answers10
41
Well, both ls and rm operate on the arguments which are passed to them.
These arguments can be a simple file, so ls file.ext and rm file.ext operate on the same file and the outcome is clear (list the file / delete the file).
If instead argument is a directory, ls directory lists the content of the directory while rm directory won't work as is (i.e. rm without flags cannot remove directories, while if you do rm -r directory, it recursively deletes all files under directory and the directory itself).
But keep in mind that command line arguments can be subjected to shell expansion, so it's not always guaranteed that the same arguments are passed to both commands if they contain wildcards, variables, output from other commands, etc.
As an extreme example think ls $(rand).txt and rm $(rand).txt, the arguments are "the same" but the results are quite different!
21
If you're thinking of something like ls foo*.txt vs. rm foo*.txt, then yes, they will show and remove the same files. The shell expands the glob, and passes it to the command in question, and the commands work on the listed files. One listing them, one removing them.
The obvious difference is that if any of those files happened to be a directory, then ls would list its contents, but rm would fail to remove it. That's usually not a problem, since rm would remove less than what was shown by ls.
The big issue here comes from running ls * or rm * in a directory containing filenames starting with a dash. They would expand to the command lines of the two programs as if you wrote them out yourself, and ls would take -r to mean "reverse sort order", while rm would take -r to mean a recursive removal. The difference matters if you have subdirectories at least two levels deep. (ls * will show the contents of the first level directories, but rm -r * will everything past the first sublevel, too.)
To avoid that, write permissive globs with a leading ./ to indicate the current directory, and/or put a -- to signal the end of option processing before the glob (i.e. rm ./* or rm -- *).
With a glob like *.txt, that's actually not an issue since the dot is an invalid option character, and will cause an error (until someone expands the utilities to invent a meaning for it), but it's still safer to put the ./ there anyway.
Of course you could also get different results for the two commands if you changed the shell's globbing options, or created/moved/removed files in between the commands, but I doubt you meant any of those cases. (Dealing with new/moved files would be extremely messy to do safely.)
ilkkachu
  • 1,887
18
Leaving aside shell behavior,let's focus on only what rm and ls can deal with themselves. At least one case where ls will show what rm can't remove involves directory permissions, and the other - special directories . and ...
Folder permissions
rm is an operation on a directory, because by removing a file, you're changing directory contents ( or in other words listing of directory entries,since directory is nothing more than a list of filenames and inodes). This means you need write permissions on a directory. Even if you are the owner of the file, without directory permissions you can't remove files. The reverse is also true: rm can remove files that may be owned by others, if you are directory owner.
So you may very well have read and execute permissions on a directory, which will allow you traverse the directory and view contents within just fine, for example ls /bin/echo, but you can't rm /bin/echo unless you are the owner of /bin or elevate your privileges with sudo.
And you'll see cases like this everywhere. Here's one such case: https://superuser.com/a/331124/418028
Special directories '.' and '..'
Another special case is . and .. directories. If you do ls . or ls .. , it will happily show you the contents, but rm'ing them is not allowed:
$ rm -rf .
rm: refusing to remove '.' or '..' directory: skipping '.'
15
If you type ls * and then rm *, it's possible you'll remove more files than ls showed - they might have been created in the tiny time interval between the end of ls and start of rm.
choroba
  • 10,313
ls * and rm * are not responsible for expanding the glob - that's done by the shell before passing it to the command.
This means that you can use any command with the expanded filelist - so I would use something that does as little as possible.
So a better way to do this (or at the least, another way) is to skip the middle-man.
echo * will show you exactly what would be passed to your rm command.
Shadow
  • 193
If you do only ls instead of ls -a, yes rm can remove hidden files you haven't seen with ls without -a.
Example :
According to :
dir_test
├── .test
└── test2
ls dir_test : will display only test2
ls -A dir_test : will display test2 + .test
rm -r dir_test : will remove all (.test + test2)
I hope that will help you.
DevHugo
  • 121
How about:
$ mkdir what
$ cd what
$ mkdir -p huh/uhm ./-r
$ ls *
uhm
$ rm *
$ ls
-r
$ ls -R
-r
./-r:
Basically wildcards expanding to stuff starting with - (or manually entered stuff starting with - but that looks a bit more like cheating) may be interpreted differently by ls and rm.
There are edge cases where what ls shows is not what rm removes. A rather extreme, but fortunately benign one is if the argument you pass is a symbolic link to a directory: ls will show you all the files in the symlinked directory, while rm will remove the symlink, leaving the original directory and its contents untouched:
% ln -s $HOME some_link
% ls some_link    # Will display directory contents
bin    lib    Desktop ...
% rm some_link
% ls $HOME
bin    lib    Desktop ...
alexis
  • 1,028
There are already many good answers, but I want to add some more deep insight.
Ask yourself the question: How many parameters are passed to ls, if you write
ls *
...? Note that the ls command does not get the * as parameter if there are any files that * can be expanded to. Instead, the shell first performs globbing before invoking the command, so the ls command actually gets as many parameters as there are files matched by the globbing. To suppress globbing, quote the parameter.
This is true for any command: echo * vs echo '*'.
There is a script, call it countparams.sh to test the effect. It tells you how many parameters it got passed and lists them.
#!/bin/bash
echo "This script was given $# parameters."
arr=( "$@" )
for ((i=0;i<$#;i++)); do
        echo "Parameter $((i+1)): ${arr[$i]}"
done
Make it executable and run ./countparams.sh *. Learn from its output!
rexkogitans
  • 316
  • 14
The glob will expand the same way both times, if the directory contents are the same at those two different times.
If you really want to check what will be removed, use rm -i *.txt. It will prompt you separately for each file before (trying to) remove it.
This is guaranteed to be safe against race conditions:
        ls *.txt / a new file is created / rm *.txt
because you're prompted for every file by the same program that's doing the removal.
This is too cumbersome for normal use, and if you alias rm to rm -i, you'll find yourself using \rm or rm -f fairly often. But it is worth at least mentioning that there is a solution to the race condition. (It's even portable to non-GNU systems: POSIX rm(1) specifies the -i option.)
Another option would be a bash array: to_remove=(*.txt), then ask the user to confirm (perhaps after doing ls -ld -- "${to_remove[@]}"), then rm -- "${to_remove[@]}". So glob expansion is only done once, and the list is passed verbatim to rm.
Another practically-usable option is GNU rm -I (man page), which prompts if removing more than 4 items. (But doesn't show you the list, just the total.) I use alias rm='rm -I' on my desktop.
It's a nice safeguard against fat-fingering return with a half-typed pattern that matches too much. But using ls first is generally good in a directory you own, or on a single-user system, and when there aren't background processes that could asynchronously create new files there. To guard against fat-fingering, don't type rm -rf /foo/bar/baz from left to right. rm -rf / is special-cased, but rm -rf /usr isn't!  Leave out the -rf part, or start with ls, and only add the rm -rf part after typing the path.
Peter Cordes
  • 2,287
