I have a problem with wi-fi adapter. They are not found! My laptop is HP-Pavilion-15-cw0xxx with Windows 10. In Windows 10 wifi works very well! I did following:
lspci -knn | grep Net -A2
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:b822]
    Subsystem: Hewlett-Packard Company Device [103c:831b]
    Kernel modules: **r8822be**, wl, rtl8822be
ilya@ilya-HP-Pavilion-Laptop-15-cw0xxx:~$ sudo lshw -c network
[sudo] password for ilya:
  *-network UNCLAIMED
       description: Network controller
       product: Realtek Semiconductor Co., Ltd.
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:f000(size=256) memory:fea00000-fea0ffff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eno1
       version: 15
       serial: b4:b6:86:ea:93:36
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=**r8169** driverversion=2.3LK-NAPI duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.0.102 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:46 ioport:e000(size=256) memory:fe904000-fe904fff memory:fe900000-fe903fff
Also I add wl, rtl8822be in blacklist and do following:
echo -e "blacklist r8822be\n\# blacklist wl\nblacklist rtl8822be" | sudo tee /etc/modprobe.d/test_ban.conf
Also, I even switch off secure boot, but it doesn't help.
I am a biginner user of Ubuntu. Do you have any advices or solutions of my proplems?
Best regars, Ilia
guiverc
  • 33,561
Elijah
  • 13
Step1 : You must need a temporary ethernet internet connection (LAN cable or USB tethering from phone or wifi adapter)
Step2 : Once you have an active internet connection. Open the terminal and check for Wifi Driver Available in the kernel
$ lspci -knn | grep -i Net -A2
From the output we can see the current wifi driver is :
Lenovo RTL8821CE 802.11ac PCIe Wireless Network Adapter
Step3 : Search for ‘RTL8821CE Driver’, there is not yet a Wifi Driver for the Realtek RTL8821CE in the official Ubuntu Repositories.
There is a git repo : https://github.com/tomaspinho/rtl8821ce.git . Clone to that git repo
$ git clone https://github.com/tomaspinho/rtl8821ce.git
Step 4 (Optional):If you are getting any error like git not installed or gcc is not present , install them by:
$ apt install gcc $ apt install git $ apt install make
After installing above three packages rerun step3.
Step 4 : Once the git repository for the RTL8821CE Driver is downloaded, go to corresponding folder :
$ cd rtl8821ce
Step 5 : Compile the driver by using make utility.
$ make all $ make install
Step 6 : Insert the driver module to the kernel using ‘modprobe’ program.
modprobe -a 8821ce
Step 7 : reboot if necessary
Step 8 : We’ve successfully resolved the wifi problem by using above steps, But the wifi connection got intermittent without any specific reason, later we fixed that issue by changing power management options in Ubuntu.
$ nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Change wifi.powersave from 3 to 2.
Please let me know if you ever faced any issues, I’ll be happy to solve.
I solved this problem that:
echo -e "# blacklist r8822be\n\ blacklist wl\nblacklist rtl8822be" | sudo tee /etc/modprobe.d/test_ban.conf
sudo apt remove bcmwl-kernel-source
And switch off secure boot!
Elijah
  • 13
