I have one older 15-inch laptop (HP Notebook) and two newer 14-inch laptops (Lenovo Ideapad and HP Pavilion). The same thing is happening when I use Ubuntu on the two newer ones, but not on the older one.
There's no wifi icon, and when I go to the wifi settings I get this message: "No Wi-Fi Adapter Found. Make sure you have a Wi-Fi adapter plugged and turned on".
I actually installed Ubuntu on the Lenovo, but I only chose the "try Ubuntu" option with the other two. I tried it with the two most recent versions, 18.04.2 LTS and 19.04, with the same effect.
I'm surprised that this problem seems rare, as I couldn't find anything very helpful online. This seems the closest to my problem, and it suggests reinstalling a kernel, but without internet, I'm obviously getting network errors in my terminal. The two problematic computers unfortunately don't have ethernet ports either, so I have no idea what to do..
Here's the output to sudo lshw -class network (hopefully it's the relevant wireless card info):
*-network UNCLAIMED description: Network controller product: Realtek Semiconductor Co., Ltd. Vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:02:00.0 version: 00 width: 64 bits clock: 33 MHz capabilities: pm msi pciexpress cap_list configuration: latency=0 resources: ioport:2000(size=256) memory:c0700000-c070ffff
Output of "lspci -v":
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b822
  Subsystem: Lenovo Device b023
  Flags: fast devsel, IRQ 255
  I/O ports at 2000 [size=256]
  Memory at c0700000 (64-bit, non-prefetchable) [size=64K]
  Capabilities: <access denied>
  Kernel modules: r8822be
A lot of hardware doesn't work if you don't have the firmware installed. Have you tried pulling in firmware-linux-nonfree?
Also, could you give us the output of 'lspci -v'? This should give us the model, hopefully.
