I have recently a purchased Lenovo Thinkpad E480 laptop, I have installed Ubuntu 18.04 on it, everything is working fine except am not able to connect to network via WiFi. Please help.
I followed this link, but am unable to solve the issue.
Below are the outputs of some commands.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.1 LTS
Release:    18.04
Codename:   bionic
uname -r
4.15.0-33-generic
rfkill list all
0: tpacpi_bluetooth_sw: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
lspci -nnk | grep 0280 -A3
05:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
    Subsystem: Lenovo RTL8821CE 802.11ac PCIe Wireless Network Adapter [17aa:c024]
06:00.0 SD Host controller [0805]: O2 Micro, Inc. SD/MMC Card Reader Controller [1217:8621] (rev 01)
    Subsystem: Lenovo SD/MMC Card Reader Controller [17aa:5068]
sudo lshw -C network
 *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 10
       serial: 8c:16:45:a3:d9:f1
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-3_0.0.1 04/23/13 ip=192.168.2.2 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:16 ioport:d000(size=256) memory:f1204000-f1204fff memory:f1200000-f1203fff
  *-network UNCLAIMED
       description: Network controller
       product: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:05:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:c000(size=256) memory:f1100000-f110ffff
It seems I have to clone, compile and install the required WiFi driver, please guide me which WiFi driver to use and how to install (with steps if possible).
P.S.: Let me know if any further information is needed to solve this issue, I will add the required info (if any) in the question as per the guidance given.
With a temporary working internet connection by ethernet, tethered or any other means, open a terminal Ctrl+Alt+t and do:
sudo apt update
sudo apt install build-essential git dkms
git clone https://github.com/tomaspinho/rtl8821ce.git
cd rtl8821ce
sudo ./dkms-install.sh
The file builds for me on my 18.04 system with a few possibly harmless warnings but no errors.
Follow with:
sudo modprobe 8821ce
You should be all set.
chili555
  • 61,330
