I'm trying to get a second display to work via the HDMI port on a GeForce 1030. It works if I boot into Windows, but not in Ubuntu.
ubuntu-drivers devices returns:
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001D01sv00001028sd000011C7bc03sc00i00
vendor : NVIDIA Corporation
model : GP108 [GeForce GT 1030]
driver : nvidia-driver-390 - third-party free
driver : nvidia-driver-396 - third-party free recommended
driver : xserver-xorg-video-nouveau - distro free builtin
So I ran sudo apt get nvidia-driver-396 which succeeded. I setup the MOK password when prompted. I rebooted, then went through the "enroll MOK" flow. Ubuntu then shows the boot log for a time then hangs, the last command being "Started Network Manager Script Dispatcher Service" which I assume is irrelevant. I'm able to start a session with CTRL + ALT + F2 and uninstall the drivers with sudo apt purge nvidia*, then successfully sudo reboot.
I am also unable to boot with the nvidia-driver-390 version.
Any help debugging?
Update:
I checked out the systemctl log while it's hanging and it's full of repeated log items from "nvidia-persistenced" that look like:
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Verbose syslog connection opened
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Now running with user ID 123 and group ID 129
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Started (1399)
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: device 0000:01:00.0 - registered
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Local RPC service initialized
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Received signal 15
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Socket closed.
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: PID file unlocked.
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: PID file closed.
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
Aug 23 17:23:48 brianubuntu nvidia-persistenced[1399]: Shutdown (1399)
edit: I attempted all the potential fixes in this post including purging and the reinstalling drivers from TTY, trying older versions of the drivers, and booting with different GRUB settings. Still no luck.
