14
I received the notice that there's an update for my desktop install, but I'm unable to do so. There's no real error messages that I can see. I've run sudo apt autoremove, sudo apt upgrade, and sudo apt install, and it gives 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. This is my screen when I run do-release-upgrade:
Reading cache
Checking package manager
Reading package lists... Done
Building dependency tree
Hit http://us.archive.ubuntu.com/ubuntu xenial InRelease
Hit http://archive.canonical.com xenial InRelease
Hit http://security.ubuntu.com/ubuntu xenial-security InRelease
Fetched 0 B in 0s (0 B/s)
Restoring original system state
Aborting
=== Command detached from window (Mon Aug 20 20:34:56 2018) ===
This is my main.log:
2018-08-20 20:34:50,649 INFO Using config files '['./DistUpgrade.cfg.xenial']'
2018-08-20 20:34:50,649 INFO uname information: 'Linux egwene 4.4.0-133-generic #159-Ubuntu SMP Fri Aug 10 07:26:31 UTC 2018 i686'
2018-08-20 20:34:50,862 INFO apt version: '1.2.15ubuntu0.2'
2018-08-20 20:34:50,862 INFO python version: '3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609]'
2018-08-20 20:34:50,864 INFO release-upgrader version '18.04.24' started
2018-08-20 20:34:50,868 INFO locale: 'en_US' 'UTF-8'
2018-08-20 20:34:51,059 DEBUG Using 'DistUpgradeViewText' view
2018-08-20 20:34:51,111 DEBUG enable dpkg --force-overwrite
2018-08-20 20:34:51,150 DEBUG creating statefile: '/var/log/dist-upgrade/apt-clone_system_state.tar.gz'
2018-08-20 20:34:54,329 DEBUG lsb-release: 'xenial'
2018-08-20 20:34:54,330 DEBUG _pythonSymlinkCheck run
2018-08-20 20:34:54,331 DEBUG openCache()
2018-08-20 20:34:54,332 DEBUG No such plugin directory: ./plugins
2018-08-20 20:34:54,332 DEBUG plugins for condition 'PreCacheOpen' are '[]'
2018-08-20 20:34:54,332 DEBUG plugins for condition 'bionicPreCacheOpen' are '[]'
2018-08-20 20:34:54,332 DEBUG plugins for condition 'from_xenialPreCacheOpen' are '[]'
2018-08-20 20:34:54,333 DEBUG quirks: running PreCacheOpen
2018-08-20 20:34:54,333 DEBUG running Quirks.PreCacheOpen
2018-08-20 20:34:54,721 DEBUG /openCache(), new cache size 56038
2018-08-20 20:34:54,721 DEBUG need_server_mode(): run in 'desktop' mode, (because of pkg 'ubuntu-desktop')
2018-08-20 20:34:54,721 DEBUG checkViewDepends()
2018-08-20 20:34:54,721 DEBUG running doUpdate() (showErrors=False)
2018-08-20 20:34:55,529 DEBUG openCache()
2018-08-20 20:34:55,939 DEBUG /openCache(), new cache size 56038
2018-08-20 20:34:55,940 DEBUG doPostInitialUpdate
2018-08-20 20:34:55,940 DEBUG plugins for condition 'PostInitialUpdate' are '[]'
2018-08-20 20:34:55,940 DEBUG plugins for condition 'bionicPostInitialUpdate' are '[]'
2018-08-20 20:34:55,940 DEBUG plugins for condition 'from_xenialPostInitialUpdate' are '[]'
2018-08-20 20:34:55,940 DEBUG quirks: running bionicPostInitialUpdate
2018-08-20 20:34:55,940 DEBUG running Quirks.bionicPostInitialUpdate
2018-08-20 20:34:55,951 DEBUG abort called
2018-08-20 20:34:55,951 DEBUG openCache()
2018-08-20 20:34:55,951 DEBUG failed to SystemUnLock() (E:Not locked)
2018-08-20 20:34:56,356 DEBUG /openCache(), new cache size 56038
What could be the problem here?
Edit
Using the link provided by WinEunuuchs2Unix, here are my PPA links:
'http://us.archive.ubuntu.com/ubuntu/ xenial main restricted'
'http://us.archive.ubuntu.com/ubuntu/ xenial universe'
'http://us.archive.ubuntu.com/ubuntu/ xenial multiverse'
'http://security.ubuntu.com/ubuntu xenial-security main restricted'
'http://security.ubuntu.com/ubuntu xenial-security universe'
'http://security.ubuntu.com/ubuntu xenial-security multiverse'
'http://archive.canonical.com/ xenial partner'
iammilind
  • 2,247
aynber
  • 241
sudo apt remove --purge snapd
Tried all options from various threads but above has fixed the problem for me
try:
sudo apt-get install lsb-core
and then upgrade
Sometimes this package is missing or corrupted and the installer has hard time figuring out which version is currently running, There are lots of complains about that if you google it. The same might happen in Debian.
jet
  • 7,452
Ubuntu has stopped supporting 32bit desktop systems as of 17.10. The latest version of 32bit is 16.04.5, per https://www.ubuntu.com/download/alternative-downloads .
aynber
  • 241
wow so blind I am.
I miss xenial-updates package source.
Expand your /etc/apt/sources.list
deb http://us.archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
Update xenial
sudo apt update && sudo apt full-upgrade
Then try again. If this is not working I'm out of ideas.
And you know backup 1.
nobody
  • 5,792
