Whn running do-release-upgrade
I get the following
Checking package manager
Reading package lists... Done
Building dependency tree
Calculating the changes
Could not determine the upgrade
An unresolvable problem occurred while calculating the upgrade.
This can be caused by:
* Upgrading to a pre-release version of Ubuntu
* Running the current pre-release version of Ubuntu
* Unofficial software packages not provided by Ubuntu
If none of this applies, then please report this bug using the
command 'ubuntu-bug ubuntu-release-upgrader-core' in a terminal.
Restoring original system state
When running grep Broken /var/log/dist-upgrade/apt.log
Broken grub-common:amd64 Conflicts on grub-common:i386 < none -> 2.02-2ubuntu8.1 @un uN Ib >
Broken grub2-common:amd64 Conflicts on grub2-common:i386 < none -> 2.02-2ubuntu8.1 @un uN Ib >
Broken libsmbios-c2:amd64 Conflicts on libsmbios2v5:amd64 < 2.3.1-0ubuntu2 @ii mK Ib >
Broken os-prober:amd64 Conflicts on os-prober:i386 < none -> 1.74ubuntu1 @un uN Ib >
Broken libcurl4:amd64 Conflicts on libcurl3:amd64 < 7.55.1-1ubuntu2.5 -> 7.58.0-2ubuntu2 @ii umU Ib >
Broken shim-signed:amd64 Depends on grub2-common:amd64 < 2.02~beta3-4ubuntu7.3 -> 2.02-2ubuntu8 @ii umU > (>= 2.02-2ubuntu8.1)
Broken gnome-themes-extra-data:amd64 Conflicts on gnome-themes-standard-data:amd64 < 3.22.3-1ubuntu2 -> 3.22.3-3ubuntu2 @ii umU >
Broken gnome-themes-extra-data:amd64 Conflicts on gnome-themes-standard-data:i386 < none @un H >
Broken librubberband2:amd64 Conflicts on librubberband2v5:amd64 < 1.8.1-6ubuntu2 @ii mK Ib >
Broken dkms:amd64 Breaks on shim-signed:amd64 < 1.33.1~17.10.1+13-0ubuntu2 | 1.34.9.2+13-0ubuntu2 @ii umH > (< 1.34~)
It seems grub is correct though
sudo dpkg -l | grep ^..r shows nothing.
Any suggestions for fixing ?
