I had Ubuntu 16.04 on an old Compaq laptop and it worked seamlessly. Recently, it suggested I update to Ubuntu 18.04. Then the nightmare began. After installing, the laptop uncontrollably flickered, at times making it impossible to use. I went back to 16.04 and the flicker was there also, so I'm guessing 18.04 changed the video settings.
I tried dozens of sudo this and that, and finally got 18.04 to stop flickering, but honestly I cannot recall which sudo command worked. I do know that the Nvidia sudo command completely locked me out of Ubuntu. Once it was stable, I went to Netflix to watch a video, but it was no good. I got some error message/number and searched for a fix. I ran another sudo to fix it, and then the flickering screen came back.
I can't use Windows 10 on the old laptop (it runs as fast as a turtle sleeping), and I can't go back to Ubuntu 16.04 because the flickering screen is still there.
I'm in a nightmare. Any help?
karel
  • 122,292
  • 133
  • 301
  • 332
I feel like I was just in your same shoes, then I found this answer: Graphics problem on Ubuntu 18.04 - blurred text + screen flickering
Try that by removing the following from /etc/environment if it's there:
CLUTTER_PAINT=disable-clipped-redraws:disable-culling
CLUTTER_VBLANK=True`
Yes, more sudo. Use your favorite editor, modify the file, then reboot. I would do it like this:
sudo nano /etc/environment
Delete the lines above, save with ctrl+x, y to accept, and reboot:
sudo reboot
Nick_4
