I installed Ubuntu 18.04 a day ago. It works perfectly but graphics is a problem; I see screen flickering where there are system or JS overlays and blurred text.
What can I do - my graphics are based on intel chip
Running sudo lshw -c display
I get
*-display
   description: VGA compatible controller
   product: HD Graphics 520
   vendor: Intel Corporation
   physical id: 2
   bus info: pci@0000:00:02.0
   version: 07
   width: 64 bits
   clock: 33MHz
   capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
   configuration: driver=i915 latency=0
   resources: irq:127 memory:b0000000-b0ffffff memory:a0000000-afffffff ioport:3000(size=64) memory:c0000-dffff
Check the terminal output screenshot
To get rid of the flicker, I had to REMOVE these two lines from /etc/environment (you probably don't have them, unless you installed gnome-wobbly-windows extension)
CLUTTER_PAINT=disable-clipped-redraws:disable-culling
CLUTTER_VBLANK=True
And I also had to run sudo ubuntu-drivers autoinstall and then reboot
For nVidia cards: To make the text non-blurry, I just increased the screen resolution via nvidia-settings (the Display dialog did not let me change the resolution)
Jonathan
  • 3,984
