I have upgraded to 18.04 and find that if I attempt to launch gedit from a terminal, I only get a small window showing part of the screen, which is a bit like a screenshot. I can close the application again once I find the window and the close icon.
If I prefix the command with sudo it's OK. I want to continue to start ubuntu with the default xorg, if I start with wayland, then I don't need the 'sudo' prefix. Under wayland, starting with sudo gedit produces the same error as xorg without the 'sudo'.
I am asking if there is any known workaround for this mildly irritating bug?
EDIT
It's become more annoying, as when in File Manager and I click on a file it opens gedit with the same error. I did change the owner with Norbert's suggestion but to no effect.
I've now installed Leafpad and set it to be the default application and that works OK but I'd rather go back to having gedit.
NickT
  • 2,223
It may help if you purge gedit, and then install it again,
sudo apt purge gedit
and after that
sudo apt install gedit
From man apt,
   install, remove, purge (apt-get(8))
       Performs the requested action on one or more packages specified via
       regex(7), glob(7) or exact match. The requested action can be
       overridden for specific packages by append a plus (+) to the
       package name to install this package or a minus (-) to remove it.
   A specific version of a package can be selected for installation by
   following the package name with an equals (=) and the version of
   the package to select. Alternatively the version from a specific
   release can be selected by following the package name with a
   forward slash (/) and codename (stretch, buster, sid ...) or suite
   name (stable, testing, unstable). This will also select versions
   from this release for dependencies of this package if needed to
   satisfy the request.
   Removing a package removes all packaged data, but leaves usually
   small (modified) user configuration files behind, in case the
   remove was an accident. Just issuing an installation request for
   the accidentally removed package will restore its function as
   before in that case. On the other hand you can get rid of these
   leftovers by calling purge even on already removed packages. Note
   that this does not affect any data or configuration stored in your
   home directory.
But you may still need to identify data or configurations stored in your home directory and change ownership from root to your user ID.
sudodus
  • 47,684
According to the answer provided by steffel in this thread. I've made these steps:
  1. sudo vim /etc/default/im-config (or any editor you want to open the file with sudo).
  2. Add this line GTK_IM_MODULE=none at the end of the file.
  3. Reboot your device.
These steps solved the problem for me.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
