I upgraded to Kubuntu 18.04 recently but do not see the Slovak keyboard layout (in "Keyboard - System Settings Module" ). Is there any way how to add it?
This layout was normally available for older Kubuntu versions.
I don't have access to a Kubuntu desktop at the moment, but you can try to add it system wide.
Open the /etc/default/keyboard file for editing. If you for instance have the English (US) layout set by default, you probably find these two lines:
XKBLAYOUT="us"
XKBVARIANT=""
You can add Slovak by changing those lines so they look like this:
XKBLAYOUT="us,sk"
XKBVARIANT=","
Hopefully Slovak will then be available after next reboot.
Edit:
/etc/default/keyboard corresponding to setxkbmap() command in comment:
XKBLAYOUT="us,sk"
BACKSPACE="guess"
XKBVARIANT=",qwerty"
XKBMODEL="pc105"
XKBOPTIONS="grp:alt_shift_toggle"
