My hardware is pretty new; I've installed Lubuntu 11.10 and there's no sound nor volume icon in tray. The sound works well in Ubuntu. What can I do about it? I have two sound cards in this laptop, and one of them is HDMI, maybe the problem is because of that? Please help me?! Thanks.
marcel
  • 31
Lubuntu unlike Ubuntu does not make use of Pulseaudio. Instead it uses Alsa for sound.
Thus, it is likely you need to look at alsamixer or its gui alsamixgui to control which sound elements are enable or disabled.
You may also need to look at using alsamixer as a startup application with the syntax similar to
amixer -c 1 sset "PCM Capture Source" "Line" - obviously you need to change the values to your sound source and output type.
Also - look to see if you have two sound cards - if you have, sometimes swapping the cards works:
sudo su
cd /usr/share/alsa
cp -p alsa.conf alsa.conf.dist
sed -i 's/card 0/card 1/g' alsa.conf
I answered a LXDE sound-preferences question a while back which you may find useful.
As indicated in that answer, you could also install pulseaudio and use pavucontrol to control your pulseaudio setup.
As to a LXDE friendly volume control, my answer here is an accepted method you can try.
fossfreedom
  • 174,526
I finally got sound working on HDMI. It was very interesting find though.
I saw differences in Pavucontrol without a video playing and with a video playing.. All i had to do was open Pavucontrol with a video playing and then select output to HDMI card.
Hope this helps all..
This is what I did to fix the issue:
Lubuntu shares many components with XFCE. My suggestion would be to use the XFCE4-Mixer. This still gives you a lightweight solution compatible with the lxde ethos.
to install
sudo apt-get install xfce4-mixer gstreamer0.10-alsa
This installs the following limited number of xfce packages:
exo-utils libgarcon-1-0 libgarcon-common libwnck-common libwnck22 libxres1 xfce4-mixer xfce4-panel
to run
Type xfce4-mixer in a lxterminal. In Options, in the Auto-Mute Mode drop-down menu, select "Disabled."
Credit: This is a close but not exact derivative of this answer by fossfreedom and anonranger.
This may help: http://forum.xbmc.org/showthread.php?tid=76544&pid=1069025#pid1069025
oscar
