After having updated to Ubuntu 18.04, when I try to upgrade my system via
sudo apt update && sudo apt upgrade
I get this:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
gdb gir1.2-peas-1.0 libpeas-1.0-0 openshot
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Of course I tried sudo apt install -f without success:
$ sudo apt install -f
One suggested solution was to install each separately, but that doesn't work either:
$ sudo apt install libpeas-1.0-0
libpeas-1.0-0 : Depends: libpython3.6 (>= 3.6.4~rc1) but it is not going to be installed
So I tried to install libpython3.6, which doesn't work because
libpython3.6 : Depends: libpython3.6-stdlib (= 3.6.5-3) but 3.6.5-5~16.04.york1 is to be installed
Now I can't remove/install/downgrade to this version because apt would then remove about 200 packages including things like xorg, firefox, gnome-session and pretty much every package I ever heard of.
One other thing I wanted to try taken from the question here was
sudo dpkg --install --force all /var/cache/apt/archives/libpython3[version].deb
but there was no file with my needed version number.
Edit: I downloaded the specific version via apt download libpython3.6-stdlib=3.6.5-3 and installed it with above command. Now I can neither do upgrade nor autoremove, and I get this warning for both:
libpython3.6-stdlib : Depends: libpython3.6-minimal (= 3.6.5-3) but 3.6.5-5~16.04.york1 is installed
python3.6 : Depends: libpython3.6-stdlib (= 3.6.5-5~16.04.york1) but 3.6.5-3 is installed
What else can I do? Thanks for any help.
