You might want to run 'apt-get -f install' to correct these.
libpython3.6 : Depends: libpython3.6-stdlib (= 3.6.5-5~16.04.york1) but 3.6.5-5~16.04.york0 is installed
libpython3.6-dev : Depends: libpython3.6-stdlib (= 3.6.5-5~16.04.york1) but 3.6.5-5~16.04.york0 is installed
libpython3.6-stdlib : Depends: libpython3.6-minimal (= 3.6.5-5~16.04.york0) but 3.6.5-5~16.04.york1 is installed
E: Unmet dependencies. Try using -f.
I had installed using PPA JonathanF in Ubuntu 16.04, and it was working fine until I encountered this issue today.
TI tried and got the below error:
$ sudo apt-get upgrade -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
Calculating upgrade... Done
The following packages will be upgraded:
libpython3.6-stdlib
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/1,989 kB of archives.
After this operation, 1,393 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 231399 files and directories currently installed.)
Preparing to unpack .../libpython3.6-stdlib_3.6.5-5~16.04.york1_amd64.deb ...
Unpacking libpython3.6-stdlib:amd64 (3.6.5-5~16.04.york1) over (3.6.5-5~16.04.york0) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.6-stdlib_3.6.5-5~16.04.york1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.6/lib2to3/refactor.py', which is also in package python3-lib2to3 3.6.5-3~16.04.york0.2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
