So, I recently got a ticket from a client complaining that our software was crashing on his ubuntu 16.04 PC. He stated that the software was working originally but when he tried using it some time later, the software crashes.
His original run gave the following errors / warnings:
libGL error: unable to load driver: nouveau_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: nouveau
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Unrecognized OpenGL version
QMetaObject::connectSlotsByName: No matching signal for on_pushButton_browse_released()
QMetaObject::connectSlotsByName: No matching signal for on_checkBox_localRunMode_toggled(bool)
QMetaObject::connectSlotsByName: No matching signal for on_checkBox_remoteRunMode_toggled(bool)
QObject::connect: No such slot S3DGui::slotOnCentralTabChanged(int)
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
QFileInfo::absolutePath: Constructed with empty filename
QOpenGLWidget: Failed to make context current
composeAndFlush: makeCurrent() failed
Segmentation fault (core dumped)
I followed the answer @ Error in installing Steam on ubuntu 15.04 to localize the issue, but it failed.
I had asked him to send me an output of LIBGL_DEBUG, the output for that was:
$ DISPLAY=:0 LIBGL_DEBUG=verbose ./<Project_script name>
libGL: Can't open configuration file /home/<name>/.drirc: No such file or directory.
libGL: pci id for fd 9: 10de:1bb0, driver nouveau
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/tls/nouveau_dri.so
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so
libGL: dlopen /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so failed (/usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1: undefined symbol: drmSyncobjWait)
libGL: OpenDriver: trying ${ORIGIN}/dri/tls/nouveau_dri.so
libGL: OpenDriver: trying ${ORIGIN}/dri/nouveau_dri.so
libGL: dlopen ${ORIGIN}/dri/nouveau_dri.so failed (${ORIGIN}/dri/nouveau_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/dri/tls/nouveau_dri.so
libGL: OpenDriver: trying /usr/lib/dri/nouveau_dri.so
libGL: dlopen /usr/lib/dri/nouveau_dri.so failed (/usr/lib/dri/nouveau_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so
libGL: dlopen /usr/lib/x86_64-linux-gnu/dri/swrast_dri.so failed (/usr/lib/x86_64-linux-gnu/libdrm_amdgpu.so.1: undefined symbol: drmSyncobjWait)
libGL: OpenDriver: trying ${ORIGIN}/dri/tls/swrast_dri.so
libGL: OpenDriver: trying ${ORIGIN}/dri/swrast_dri.so
libGL: dlopen ${ORIGIN}/dri/swrast_dri.so failed (${ORIGIN}/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL: OpenDriver: trying /usr/lib/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/dri/swrast_dri.so
libGL: dlopen /usr/lib/dri/swrast_dri.so failed (/usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
function is no-op
As you can see the project uses Qt and OpenGL. I don't really have any idea of what the issue might be. Any suggestions would be appreciated.
P.S I noticed that his libraries as in lib/ folder (though he is using x86_64 libs) while ours is in lib64/ (where the code works just fine).
