I want to test Unity in a VM using VMware Player. I have already enabled 3D acceleration in the Display options and I have VMware Tools installed. However, when I try to run Unity or when I try to enable effects in appearance menu, it doesn't activate. Jockey says there is only one video driver available, which is enabled already.
I don't want to use VirtualBox.
jobin
  • 28,567
lovinglinux
  • 6,427
I do not think VMware Player supports OpenGL 3D for linux as yet. Linux support may come in future versions [probably the next one]. Compiz will definitely not work.
Only Directx windows runs on full throttle. Compiz-windows-clones[so called] work neatly.
muru
  • 207,228
Neer
  • 146
As far as I know, even compiz-based Unity is unlikely to run in a VM (I asked about this at UDS and was told compiz doesn't run on VMs.)
