188
Dual monitor setup on Ubuntu 18.04; when I hit activities only the left monitor switches workspaces while the right monitor just keeps whatever is on its screen. Is there a way to make the workspace span both monitors so that when I switch from one workspace to another both monitors switch?
Zanna
  • 72,312
Alex
  • 2,025
7 Answers7
231
Had the same problem. Turned out it was super easy to fix.
Install the GNOME Tweaks app. Go to Workspaces and set Display handling to Workspaces span displays. Done!
Zanna
  • 72,312
ehannes
  • 2,530
140
You can change this behaviour by executing:
gsettings set org.gnome.mutter workspaces-only-on-primary false
Zanna
  • 72,312
dkurzaj
  • 1,609
20
You can install gnome-tweak-tool via sudo apt install gnome-tweak-tool.
Then go to Workspaces > Display Handling > And choose Workspaces span displays
Zanna
  • 72,312
Ini
  • 440
20
In Ubuntu 22.04:
Settings > Multitasking > Multi-Monitor > Workspaces on all displays
Debmallya
  • 301
13
Install dconf-editor:
sudo apt install dconf-editor
Disable the following settings:
dconf write /org/gnome/mutter/workspaces-only-on-primary false
dconf write /org/gnome/shell/overrides/workspaces-only-on-primary false
10
I recommend to you to use the Multi Monitos Add-on extension, available in GNOME Extensions. It is pretty easy to use, and it also gives you the ability to add a panel in the second monitor.
To get up and running all the GNOME extensions config directly in your browser, you only need the following:
  1. Install the gnome-shell-extensions package:
    sudo apt install gnome-shell-extensions
  2. Install the host connector:
    sudo apt install chrome-gnome-shell
  3. Install the GNOME Shell integration extension (Chrome) or add-on (Firefox).
  4. Find and install the Multi Monitos Add-on extension.
I am speaking (only) for Ubuntu 24.04 (no earlier version, no mate, no...)
NOT working: anything multi-monitors-add-on@spin83
NOT working: anything gnome-tweaks (no longer shows a Workspaces option)
INDEED working: Onboard means (regular settings)
Frank N
  • 1,430
