I wanted to install Ubuntu the other day, but when I tried to install it to my drive, it would go with the installer and stop, and say "Cannot install grub to /dev/sda" or stuff like that, I'd click Dont install the bootloader, since I have rEFInd, but then the installer would crash, and then the USB would crash in a PCIEport bus error refreshing list, I tried installing other distros too like Elementary OS and deepin, both had the same issue, even if deepin only got stuck at 62%, I need a solution as I really want to dual boot
1) Nowdays, most of the recent hardware are Linux compatibility. But still kindly check your hardware compatibility with Linux. Kindly refer the below link:
Is There A Database of Linux compatible hardware?
2) If it is compatibility, follow the installation process in below link:
How do I install Ubuntu?
Aravind
  • 943
