ankur@ahkyp:~$ sudo apt update && sudo apt upgrade
Hit:1 http://ppa.launchpad.net/linrunner/tlp/ubuntu bionic InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
11 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3 (3.6.5-3ubuntu1) ...
running python rtupdate hooks for python3.6...
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/__init__.cpython-36.pyc.139794777489248'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/appactivatable.cpython-36.pyc.139794777486512'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/capture.cpython-36.pyc.139794777544576'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/filelookup.cpython-36.pyc.139794777508864'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/functions.cpython-36.pyc.139794777544576'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/library.cpython-36.pyc.139794777487664'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/linkparsing.cpython-36.pyc.139794777508864'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/manager.cpython-36.pyc.139794777544576'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/outputpanel.cpython-36.pyc.139794777507136'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools/__pycache__/windowactivatable.cpython-36.pyc.139794777158896'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/pythonconsole/__pycache__/__init__.cpython-36.pyc.139794777505840'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/pythonconsole/__pycache__/config.cpython-36.pyc.139794776836952'
[Errno 20] Not a directory: '/usr/lib/x86_64-linux-gnu/gedit/plugins/pythonconsole/__pycache__/console.cpython-36.pyc.139794777505840'
error running python rtupdate hook gedit
[Errno 2] No such file or directory: '/usr/share/hplip/pcard/__init__.py'
[Errno 2] No such file or directory: '/usr/share/hplip/pcard/photocard.py'
[Errno 2] No such file or directory: '/usr/share/hplip/prnt/__init__.py'
[Errno 2] No such file or directory: '/usr/share/hplip/prnt/colorcal.py'
[Errno 2] No such file or directory: '/usr/share/hplip/prnt/cups.py'
[Errno 2] No such file or directory: '/usr/share/hplip/prnt/ldl.py'
[Errno 2] No such file or directory: '/usr/share/hplip/prnt/pcl.py'
error running python rtupdate hook hplip-data
dpkg: error processing package python3 (--configure):
 installed python3 package post-installation script subprocess returned error exit status 4
dpkg: dependency problems prevent configuration of python3-update-manager:
 python3-update-manager depends on python3:any (>= 3.3.2-2~); however:
  Package python3 is not configured yet.
dpkg: error processing package python3-update-manager (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of netplan.io:
 netplan.io depends on python3; however:
dpkg: error processing package netplan.io (--configure):
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-core:
 ubuntu-release-upgrader-core depends on python3:any (>= 3.2~); however:
dpkg: error processing package ubuntu-release-upgrader-core (--configure):
dpkg: dependency problems prevent configuration of nplan:
 nplan depends on netplan.ioNo apport report written because the error message indicates its a followup error from a previous failure.
        No apport report written because MaxReports is reached already
                                                   ; however:
  Package netplan.io is not configured yet.
dpkg: error processing package nplan (--configure):
dpkg: dependency problems prevent configuration of unattended-upgrades:
 unattended-upgrades depends on python3; however:
dpkg: error processing package unattended-upgrades (--configure):
dpkg: dependency problems prevent configuration of update-manager:
dpkg: error processing package update-manager (--configure):
dpkg: dependency problems prevent processing triggers for gnome-menus:
 gnome-menus depends on python3:any (>= 3.1~); however:
dpkg: error processing package gnome-menus (--configure):
 dependency probNo apport report written because MaxReports is reached already
                                                            lems - leaving triggers unprocessed
dpkg: dependency problems prevent configuration of python3-distupgrade:
 python3-distupgrade depends on python3:any (>= 3.3.2-2~); however:
 python3-distupgrade depends on python3-update-manager (>= 1:0.196.2~); however:
  Package python3-update-manager is not configured yet.
dpkg: error processing package python3-distupgrade (--configure):
dpkg: dependency problems prevent processing triggers for ufw:
 ufw depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package ufw (--configure):
 dependency problems - leaving triggers unprocessed
dpkg: dependency problems prevent configuration of ubuntu-release-upgrader-gtk:
 ubuntu-release-upgrader-gtk depends on ubuntu-release-upgrader-core (= 1:18.04.21); however:
  Package ubuntu-release-upgrader-core is not configured yet.
 ubuntNo apport report written because MaxReports is reached already
        u-release-upgrader-gtk depends on update-manager; however:
  Package update-manager is not configured yet.
 ubuntu-release-upgrader-gtk depends on python3-distupgrade (= 1:18.04.21); however:
  Package python3-distupgrade is not configured yet.
dpkg: error processing package ubuntu-release-upgrader-gtk (--configure):
dpkg: dependency problems prevent configuration of update-manager-core:
 update-manager-core depends on python3:any (>= 3.2~); however:
 update-manager-core depends on python3-update-manager (= 1:18.04.11.3); however:
 update-manager-core depends on ubuntu-release-upgrader-core (>= 1:18.04.9); however:
dpkg: error processing package update-manager-core (--configure):
dpkg: dependency problems prevent configuration of python3-apt:
 python3-apt depends on python3 (<< 3.7); however:
 python3-apt depends on python3 (>= 3.6~); however:
 python3-apt depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-apt (--configure):
 python3
 netplan.io
 nplan
 unattended-upgrades
 update-manager
 gnome-menus
 python3-distupgrade
 ufw
 update-manager-core
 python3-apt
Arronical
  • 20,241
neutron
It seems that you have installed binary HPLIP from HP site, you can follow uninstallation procedure from this answer.
Problems with gedit may be fixed by removing problematic files/derectories:
sudo rm -rf /usr/lib/x86_64-linux-gnu/gedit/plugins/externaltools
sudo rm -rf /usr/lib/x86_64-linux-gnu/gedit/plugins/pythonconsole
And then reinstall their parent package (gedit):
sudo apt-get install --reinstall gedit
if this does not work try to reinstall it manually
cd ~/Downloads
apt-get download gedit
sudo dpkg -i --force-all gedit*.deb
Then resume normal package installation:
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt-get upgrade
N0rbert
  • 103,263
