I want to disable the audible terminal bell, and enable the visual terminal bell. I followed the instructions from this answer
$ gsettings get org.gnome.desktop.wm.preferences audible-bell
false
$ gsettings get org.gnome.desktop.wm.preferences visual-bell
true
$ gsettings get org.gnome.desktop.wm.preferences visual-bell-type
'frame-flash'
but I am getting both the audible and visual bells. Likewise, disabling the terminal bell under "Sound" in preferences disables both types.
Ideas?
Phydeaux
  • 220
Apparently, the sound is coming from Ubuntu's alert system. In Ubuntu 18.04, you need to go Setting > Sound > Sound Effects > Alert Volume > Off.
I got this answer from: Turn off error sound on Ubuntu 18.04
M Nahas
  • 41
A work-around until you find the perfect solution is to replace the bell sound with no sound. On my system the alert sound is found in:
/usr/share/sounds/ubuntu/stereo/bell.ogg
To confirm it is the same sound you hear, use:
paplay /usr/share/sounds/ubuntu/stereo/bell.ogg
Then from this answer: How to disable Alert volume from the command line?, try this:
sudo mv -v /usr/share/sounds/ubuntu/stereo/*.ogg {*.disabled}
Note this disables all sounds. For just bell.ogg use
sudo mv -v /usr/share/sounds/ubuntu/stereo/bell.ogg bell.ogg.disabled
