Accidentally executed this command and now many of my programs are not working.
sudo apt-get --purge remove libstdc++6
sudo apt now not working and some other stuff.
How do I revert this?
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.4 LTS
Release:        16.04
Codename:       xenial
edit
I followed melebius by installing via dpkg -i ,libstdc++6 and it seems successful
root@server:~# sudo dpkg -i libstdc++6_5.4.0-6ubuntu1~16.04.10_amd64.deb
Selecting previously unselected package libstdc++6:amd64.
(Reading database ... 71540 files and directories currently installed.)
Preparing to unpack libstdc++6_5.4.0-6ubuntu1~16.04.10_amd64.deb ...
Unpacking libstdc++6:amd64 (5.4.0-6ubuntu1~16.04.10) ...
Setting up libstdc++6:amd64 (5.4.0-6ubuntu1~16.04.10) ...
Processing triggers for libc-bin (2.23-0ubuntu10) ...
But when i tried to install something i get this error
root@server:~# sudo apt-get screen
apt-get: error while loading shared libraries: liblz4.so.1: cannot open shared object file: No such file or directory
root@server:~#
kalkun
According to the packages web page, dpkg should be able to work without libstdc++6 (unlike apt).
So you should be able to download the correct version libstdc++6 for your architecture manually and install it using dpkg -i, e.g.
In the case you cannot use your normal web browser on the machine in question, get the right URL elsewhere and download the file using wget, e.g.
wget http://security.ubuntu.com/ubuntu/pool/main/g/gcc-5/libstdc++6_5.4.0-6ubuntu1~16.04.10_amd64.deb
According to the following error:
you seem to have more missing required packages.
Check which package provides the file, download it and (re)install using dpkg like before. For liblz4.so.1, you need liblz4-1. Repeat this procedure with each file while APT complains about missing files.
One more thing… Your command invocation
indicates you are both logged in as root and using sudo. These two things are redundant, you need just one of them at a time.
Melebius
  • 11,750
I did the same mistake by deleting the libstdc++6, most programs were not working, apt-get as well. But I managed to restore the initial state by using.
sudo apt --fix-broken install
