How can I download this libgtkmm-2.4.so.1 for Inkscape in Ubuntu 18.04?
inkscape: error while loading shared libraries: libgtkmm-2.4.so.1:
cannot open shared object file: No such file or directory
In my case these commands helped:
sudo apt-get install --reinstall libwpg-0.3-3
sudo apt-get install --reinstall libwpd-0.10
I found them thanks post:
where recommended is the following iteration:
1) Find lacking library
ldd $(which inkscape) | grep "not found"
2) Find package containing this library
3) Install with flag --reinstall.
Something is awry with your inkscape installation as indicated by N0rbert in this comment.. The missing library package is listed as a dependency of inkscape and should have been installed when you installed inkscape.
One alternative would be to do exactly as suggested in the comment and issue the command sudo apt install libgtkmm-2.4-1v5 which is exceedingly likely solve this problem but may not address the root cause.
Personally, I would issue the following commands:
sudo apt update to update the package database from the server.
sudo apt install --reinstall inkscape to reinstall the inkscape package.
This results in a running copy of inkscape under Ubuntu 18.04. If you launch it from a terminal rather than the GUI you might notice a warning like "Failed to load canberra-gtk-module" You can either choose to ignore it (inkscape will still launch) or resolve it with sudo apt install libcanberra-gtk-module
Note: Both of the aforementioned packages require that you enable the universe repository prior to attempting to install.
I could not solve the problem you are facing and that also happens with me but I do manage to use inkscape on Ubuntu 18.04 by issuing
$ sudo apt install snapd
$ sudo snap install inkscape
$ which inkscape
/snap/bin/inkscape
Before that I tried without success
1) reinstall inkscape and gtk from ubuntu 18.04
2) install latest inkscape from dev-ppa
3) LD_LIBRARY_PATH with vmware gtk versions
My system was dist-upgraded from Ubuntu 16.04 so I think this is why it is masked by running ok on a clean 18.04 install. I am seriously considering downgrade to 16.04 as it worked perfectly
Hope the snap solves to you too Cheers
You might need to reinstall libgtkmm-2.4:
~# apt install --reinstall libgtkmm-2.4
Reading package lists... Done
Building dependency tree
Note, selecting 'libgtkmm-2.4-1v5' for regex 'libgtkmm-2.4'
Note, selecting 'libgtkmm-2.4-1c2a' for regex 'libgtkmm-2.4'
Note, selecting 'libgtkmm-2.4-dev' for regex 'libgtkmm-2.4'
Note, selecting 'libgtkmm-2.4-doc' for regex 'libgtkmm-2.4'
The following additional packages will be installed:
autoconf automake autopoint autotools-dev debhelper dh-autoreconf dh-strip-nondeterminism doc-base gir1.2-gtk-2.0
gir1.2-harfbuzz-0.0 gtkmm-documentation icu-devtools libarchive-cpio-perl libatk1.0-dev libatkmm-1.6-dev
libcairo-script-interpreter2 libcairo2-dev libcairomm-1.0-dev libfile-stripnondeterminism-perl libfontconfig1-dev
libfreetype6-dev libgdk-pixbuf2.0-dev libglibmm-2.4-dev libglibmm-2.4-doc libgraphite2-dev libgtk2.0-dev libgtkmm-3.0-doc
libharfbuzz-dev libharfbuzz-gobject0 libice-dev libicu-dev libicu-le-hb-dev libicu-le-hb0 libiculx60 libltdl-dev libpango1.0-dev
libpangomm-1.4-dev libpixman-1-dev libsigc++-2.0-dev libsm-dev libtool libuuid-perl libxcb-shm0-dev libxcomposite-dev
libxcursor-dev libxft-dev libxi-dev libxinerama-dev libxml2-utils libxrandr-dev libxrender-dev m4 po-debconf
x11proto-composite-dev x11proto-input-dev x11proto-randr-dev x11proto-xinerama-dev
Suggested packages:
autoconf-archive gnu-standards autoconf-doc dh-make dwz rarian-compat libatkmm-1.6-doc libcairo2-doc libcairomm-1.0-doc
libgtkmm-3.0-dev libgraphite2-utils libgtk2.0-doc libice-doc icu-doc libtool-doc libpango1.0-doc libsigc++-2.0-doc libsm-doc
gfortran | fortran95-compiler gcj-jdk m4-doc libmail-box-perl
The following NEW packages will be installed:
libfreetype6-dev libgdk-pixbuf2.0-dev libglibmm-2.4-dev libglibmm-2.4-doc libgraphite2-dev libgtk2.0-dev libgtkmm-2.4-dev
libgtkmm-2.4-doc libgtkmm-3.0-doc libharfbuzz-dev libharfbuzz-gobject0 libice-dev libicu-dev libicu-le-hb-dev libicu-le-hb0
libiculx60 libltdl-dev libpango1.0-dev libpangomm-1.4-dev libpixman-1-dev libsigc++-2.0-dev libsm-dev libtool libuuid-perl
libxcb-shm0-dev libxcomposite-dev libxcursor-dev libxft-dev libxi-dev libxinerama-dev libxml2-utils libxrandr-dev libxrender-dev
m4 po-debconf x11proto-composite-dev x11proto-input-dev x11proto-randr-dev x11proto-xinerama-dev
0 upgraded, 59 newly installed, 1 reinstalled, 0 to remove and 20 not upgraded.
My system had libgtkmm-2.4 installed already but for some reason didn't have the dependencies installed.
Note: This was after trying the other reinstall answers in this question (apt install --reinstall inkscape and apt-get install --reinstall libwpg-0.3-3 libwpd-0.10). Neither of those seemed to work in this case.
UPDATE: It seems that the package might have issues installing because of this error:
dpkg: error processing archive /tmp/apt-dpkg-install-aQJd54/58-libgtkmm-2.4-doc_1%3a2.24.5-2_all.deb (--unpack):
trying to overwrite '/usr/share/doc/libgtkmm-2.4-dev/examples/README', which is also in package libgtkmm-2.4-dev:amd64 1:2.24.5-2
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
So it looks like a small issue with not wanting to overwrite the README in examples causes this package to not fully install.
Running apt install --fix-broken appears to have finished the installation.
UPDATE: No, it hasn't. It's still broken, and there's apparently a bunch of people that have run into the same issue over the last decade.
