Can we set somehow Nemo or Nautilus, to show hidden files per directory like the sorting, for example?
Asked
Active
Viewed 2,084 times
In Nautilus, the "show/hide files" is global, and even applies to the file dialogs. So there for sure, you can't set it on a per folder basis.
In Nemo there is an option in the preferences under "Behavior" to "Ignore per-folder view preferences". I am not sure if that setting also applies to showing/hiding hidden files, but you may verify that the setting is off and see whether that causes nemo to also remember the setting on a per-folder basis. As I do not have nemo installed, I cannot verify at this time.
vanadium
- 97,564
