It seems you have deleted something from your encrypted filesystem. Don't panic. Load Ubuntu from Live USB. Mount partition where your encrypted home directory reside (from Nautilus for example). Assume the home directory mounted to /media/ubuntu/myHome. Then try in terminal:
ecryptfs-unwrap-passphrase /media/ubuntu/myHome/.ecryptfs/toby/.ecryptfs/wrapped-passphrase
You'll be asked for your user password and then you'll see your encryption real passphrase - copy and save it to a text file. Next run:
sudo ecryptfs-add-passphrase --fnek
Enter you passphrase obtained from previous command. You'll see two lines with Inserted auth tok with sig with something in square brackets like this [7897fd8789g7dfg] - copy and save it to text file. We'll need second of keys in square brackets. Next make directory:
sudo mkdir /media/ubuntu/decryptedHome
and run
sudo mount -t ecryptfs /media/ubuntu/myHome/.ecryptfs/toby/.Private/ /media/ubuntu/decryptedHome/
You'll be asked for some questions - allow default answers except file names decryption - allow file names encrypted and when you'll be asked for files names passphrase enter second key from square brackets [].
If everything was OK you have to find your home directory files in /media/ubuntu/decryptedHome/ directory.
