WOL was working great on Bionic until yesterday's kernel update. How to diagnose/recover it?
Edit: if set to boot from 4.15.0-23 kernel it works. If set to boot from 4.15.0-24 it does not.
Edit2: WoL can be enabled with
sudo ethtool -s [card] wol g
but it isn't persistent. Searching for how to set it every boot.
Edit3: Per a comment by Kai-Heng Feng on this bug report this was an advertent change! (and therefore not a bug)
This is because the fix of LP: #1752772 has one commit [1] that disables WoL by default.
Set WoL explicitly should solve your issue.
[1] https://github.com/torvalds/linux/commit/7edf6d314cd061e1d0a1b7bc0b511d64322c3f72
To make this persistent I created a script in /etc/network/if-up.d
#!/bin/sh
/sbin/ethtool -s [card] wol g
This re-enables WoL every boot.
It seems that Wol is disabled by default in the r8169 module for now, and now we must use userspace tools like ethtool to get it: #1752772 and r8169 ethernet card don't work after returning from suspension. See also Wake-on-lan Ubuntu support on getting Wake-on-lan persistent on boot. Or just use nm-connection-editor in Network-manager for that.
pelm
