I want to enable WOL, I have it enabled in BIOS and understand I need to configure a systemd service to re-enable the setting on boot.
interface is enp3s0 (yes I checked), and script has 775 permissions
using Ubuntu 18.04 desktop
etc/systemd/system/wol.service looks like this:
[Unit]
Description=Configure Wake-up on LAN
[Service] Type=oneshot ExecStart=/sbin/ethtool -s enp3s0 wol g
[Install] WantedBy=basic.target
When I reboot, sudo ethtool enp3s0 gives me
Wake-on: d
Should be = wake-on: g
yusisushi
  • 148
ANSWERED! you need to enable WOL in netplan, and configure a service that applies ethtool setting on reboot to specify wich (pubmg) network types wake your computer,
Ubuntu 18.04 does not use etc/network/interfaces/, but /etc/netplan/.
I didn't knew that you need to add a line in your netplan/yaml file, wakeonlan :true
      ethernets:
          enp3s0:
                  addresses: [192.168.0.99/24]
                  gateway4: 192.168.0.1
                  wakeonlan: true
                  nameservers:
                    addresses: [192.168.0.1]
I found you need to use ethtool command in combination with the netplan wakeonlan: true setting. and you need to have a service to make the ethtool command persist
in systemd/system you can add a script to specify types of WOL
I highly recommend only using g (magic packet) because if you specify pumbg you are likely to get immediate reboots after shutdown, becuase you accept ping,arp,etc... for waking!
script: etc/systemd/system/wol.service
[Unit]
yusisushi
  • 148
This seems to be common enough. I was about to try put the ethtool -s dev wol g command into a script to run when the network connects but then I found in my network connections settings in gnome/cinnamon I had an option for wake on lan to select [x] magic. It now keeps the setting on reboot.
If you can't find it anywhere, this what I was about to try:
https://serverfault.com/questions/54704/how-to-get-ethtool-wake-on-lan-setting-to-stick
Hugh
