Okay, I've tried all the typical things that every forum I've come across has suggested. Here are my /boot contents:
$ ls /boot
abi-4.4.0-101-generic config-4.4.0-98-generic System.map-4.4.0-104-generic
abi-4.4.0-103-generic grub System.map-4.4.0-89-generic
abi-4.4.0-104-generic initrd.img-4.4.0-101-generic System.map-4.4.0-92-generic
abi-4.4.0-89-generic initrd.img-4.4.0-103-generic System.map-4.4.0-93-generic
abi-4.4.0-92-generic initrd.img-4.4.0-104-generic System.map-4.4.0-96-generic
abi-4.4.0-93-generic initrd.img-4.4.0-89-generic System.map-4.4.0-97-generic
abi-4.4.0-96-generic initrd.img-4.4.0-92-generic System.map-4.4.0-98-generic
abi-4.4.0-97-generic initrd.img-4.4.0-93-generic vmlinuz-4.4.0-101-generic
abi-4.4.0-98-generic initrd.img-4.4.0-96-generic vmlinuz-4.4.0-103-generic
config-4.4.0-101-generic initrd.img-4.4.0-97-generic vmlinuz-4.4.0-104-generic
config-4.4.0-103-generic initrd.img-4.4.0-98-generic vmlinuz-4.4.0-89-generic
config-4.4.0-104-generic lost+found vmlinuz-4.4.0-92-generic
config-4.4.0-89-generic memtest86+.bin vmlinuz-4.4.0-93-generic
config-4.4.0-92-generic memtest86+.elf vmlinuz-4.4.0-96-generic
config-4.4.0-93-generic memtest86+_multiboot.bin vmlinuz-4.4.0-97-generic
config-4.4.0-96-generic System.map-4.4.0-101-generic vmlinuz-4.4.0-98-generic
config-4.4.0-97-generic System.map-4.4.0-103-generic
I've tried:
$ sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
linux-image-extra-4.4.0-109-generic : Depends: linux-image-4.4.0-109-generic but it is not installed
linux-image-extra-4.4.0-128-generic : Depends: linux-image-4.4.0-128-generic but it is not installed
linux-image-generic : Depends: linux-image-4.4.0-128-generic but it is not installed
E: Unmet dependencies. Try using -f.
which leads me to:
$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
fonts-lato libllvm3.8 linux-headers-4.4.0-101 linux-headers-4.4.0-101-generic
linux-headers-4.4.0-109 linux-headers-4.4.0-109-generic linux-headers-4.4.0-89
linux-headers-4.4.0-89-generic linux-headers-4.4.0-92 linux-headers-4.4.0-92-generic
linux-headers-4.4.0-93 linux-headers-4.4.0-93-generic linux-headers-4.4.0-96
linux-headers-4.4.0-96-generic linux-headers-4.4.0-97 linux-headers-4.4.0-97-generic
linux-headers-4.4.0-98 linux-headers-4.4.0-98-generic linux-image-4.4.0-101-generic
linux-image-4.4.0-109-generic linux-image-4.4.0-89-generic linux-image-4.4.0-92-generic
linux-image-4.4.0-93-generic linux-image-4.4.0-96-generic linux-image-4.4.0-97-generic
linux-image-4.4.0-98-generic linux-image-extra-4.4.0-101-generic
linux-image-extra-4.4.0-109-generic linux-image-extra-4.4.0-89-generic
linux-image-extra-4.4.0-92-generic linux-image-extra-4.4.0-93-generic
linux-image-extra-4.4.0-96-generic linux-image-extra-4.4.0-97-generic
linux-image-extra-4.4.0-98-generic rake ruby ruby-did-you-mean ruby-minitest
ruby-net-telnet ruby-power-assert ruby-test-unit ruby2.3
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
linux-image-4.4.0-109-generic linux-image-4.4.0-128-generic
Suggested packages:
fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 428 not upgraded.
20 not fully installed or removed.
Need to get 0 B/44.0 MB of archives.
After this operation, 135 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 583603 files and directories currently installed.)
Preparing to unpack .../linux-image-4.4.0-128-generic_4.4.0-128.154_amd64.deb ...
Examining /etc/kernel/preinst.d/
run-parts: executing /etc/kernel/preinst.d/intel-microcode 4.4.0-128-generic /boot/vmlinuz-4.4.0-128-generic
Done.
Unpacking linux-image-4.4.0-128-generic (4.4.0-128.154) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-128-generic_4.4.0-128.154_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-128-generic' to '/boot/vmlinuz-4.4.0-128-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-128-generic /boot/vmlinuz-4.4.0-128-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-128-generic /boot/vmlinuz-4.4.0-128-generic
Preparing to unpack .../linux-image-4.4.0-109-generic_4.4.0-109.132_amd64.deb ...
run-parts: executing /etc/kernel/preinst.d/intel-microcode 4.4.0-109-generic /boot/vmlinuz-4.4.0-109-generic
Done.
Unpacking linux-image-4.4.0-109-generic (4.4.0-109.132) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-4.4.0-109-generic_4.4.0-109.132_amd64.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-4.4.0-109-generic' to '/boot/vmlinuz-4.4.0-109-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.0-109-generic /boot/vmlinuz-4.4.0-109-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.4.0-109-generic /boot/vmlinuz-4.4.0-109-generic
I've also tried: (How do I free up more space in /boot? )
$ sudo apt-get purge $(dpkg -l linux-{image,headers}-"[0-9]*" | awk '/ii/{print $2}' | grep -ve "$(uname -r | sed -r 's/-[a-z]+//')")
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.4.0-101-generic : Depends: linux-image-4.4.0-101-generic but it is not going to be installed
linux-image-extra-4.4.0-103-generic : Depends: linux-image-4.4.0-103-generic but it is not going to be installed
linux-image-extra-4.4.0-109-generic : Depends: linux-image-4.4.0-109-generic but it is not going to be installed
linux-image-extra-4.4.0-128-generic : Depends: linux-image-4.4.0-128-generic but it is not going to be installed
linux-image-extra-4.4.0-89-generic : Depends: linux-image-4.4.0-89-generic but it is not going to be installed
linux-image-extra-4.4.0-92-generic : Depends: linux-image-4.4.0-92-generic but it is not going to be installed
linux-image-extra-4.4.0-93-generic : Depends: linux-image-4.4.0-93-generic but it is not going to be installed
linux-image-extra-4.4.0-96-generic : Depends: linux-image-4.4.0-96-generic but it is not going to be installed
linux-image-extra-4.4.0-97-generic : Depends: linux-image-4.4.0-97-generic but it is not going to be installed
linux-image-extra-4.4.0-98-generic : Depends: linux-image-4.4.0-98-generic but it is not going to be installed
linux-image-generic : Depends: linux-image-4.4.0-128-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
and
$ dpkg -l linux-{image,headers}-"[0-9]*" | awk '/^ii/{ print $2}' | grep -v -e `uname -r | cut -f1,2 -d"-"` | grep -e '[0-9]'
linux-headers-4.4.0-103
linux-headers-4.4.0-103-generic
linux-headers-4.4.0-62
linux-headers-4.4.0-62-generic
$ dpkg -l linux-{image,headers}-"[0-9]*" | awk '/^ii/{ print $2}' | grep -v -e `uname -r | cut -f1,2 -d"-"` | grep -e '[0-9]' | xargs sudo apt-get -y purge
