I tried to remove samba-server with this command (sudo tasksel remove samba-server) and every app even the system apps are deleted and now xubuntu is stuck at boot, just showing loading. What should I do?
Did tasksel deleted my files too?
TL;DR - it is a serious bug, do not use tasksel for removing things!
Below is available options of tasksel:
$ tasksel --help
Unknown option: help
Usage:
tasksel install <task>...
tasksel remove <task>...
tasksel [options]
-t, --test test mode; don't really do anything
--new-install automatically install some tasks
--list-tasks list tasks that would be displayed and exit
--task-packages list available packages in a task
--task-desc returns the description of a task
Samba task is named as samba-server as you wrote:
$ tasksel --list-tasks | grep -i Samba
u samba-server Samba file server
It consists of only one package:
$ tasksel --task-packages samba-server
samba-server^
If we try to simulate uninstall - we get the following line:
$ sudo tasksel --test remove samba-server
debconf-apt-progress -- apt-get -q -y \
-o APT::Install-Recommends=true \
-o APT::Get::AutomaticRemove=true -o APT::Acquire::Retries=3 \
install samba-server^-
(in the line above the last hyphen - cause problems).
What I did:
tasksel with sudo apt-get install taskselsudo tasksel install samba-serversudo tasksel remove samba-serverThen I tried to repair the system:
We need to boot in Recovery mode (click Shift on boot, in GRUB select Advanced options for Ubuntu, select Ubuntu, with Linux ... (recovery mode))
Select resume Resume normal boot to access login shell
Open first console #1 with Ctrl+Alt+1 then login
If you do not have internet - check Ethernet interface name and run DHCP-client manually on it:
ifconfig -a # got enp0s3
sudo dhclient enp0s3
Reinstall xubuntu-desktop meta-package to the system:
sudo apt-get install xubuntu-desktop
After reboot I can access the system.
So it seems that it is a serious bug - I have found some with almost same symptoms:
Also I have filed new bug 1779645 "Critical bug in tasksel: tasksel remove task-name removes whole system"
tasksel for removing things at least on 16.04 LTS, 18.04 LTS and 20.04 LTS.
