I assembled a computer and it lags a lot (especially when a browser is open).
As recommended on a different post, I ran a full Checkbox test to see what the problem is. It repeatedly returned a "disk/detect" error. Edit: it literally says nothing else on the issue. I've gone into the saved logs as well. For this test it says nothing else.
I read that that test was based on the lshw command. When I run that command, it seems to run without any problems.
How do I fix this error? Is it likely to be the cause of the laggy performance?
Edits:
I checked out the BIOS. All pieces of hardware appear to be correctly recognised.
Main Specs
CPU: Threadripper 1950X
RAM: 32 GB
Motherboard: Asrock X399 Taichi
GPU: GTX 1080 Ti
Drive: Samsung 960 NVMe. I bought it new and unused.
Software: Ubuntu 16.04
Power: 1500W - which according to pcpartpicker is a huge surplus (I designed it for multi-GPU but only have one for now).
