I can access my Android phone in Files (Nautilus), but how do I access it in Krusader?
I can type 'mtp:/' in the Location Bar, but I get this error:
"Error: Protocol not supported by Krusader: mtp:/"
What is wrong?
Henrik R.
  • 1,099
With the help of Where are MTP mounted devices located in the filesystem? I discovered that my Android phone gets mounted here: /var/run/user/1000/gvfs/ or here: /run/user/1000/gvfs/ - problem solved!
Henrik R.
  • 1,099
With recent KDE, when you connect the phone and enable file transfer on the phone, you get an option to "Browse files" in the device notifier on KDE. If you've set Krusader as your default file manager (System Settings > Personalization > Applications > Default Applications), then this will open a new tab Krusader, and show the phone's internal storage there.
I'm still looking how to do this directly from Krusader.
MichaelK
  • 159
