I'm running ubuntu 10.10 and my soundcard is a realtek alc880, with intel HDA controller. I have a very low sound, and, when I raise the volume over 50%, it sounds "cracked". When I plug the headphones in, it keeps on playing through the speakers (and the headphones don't play any sound). In windows, it sounds fine, and the headphones work well. Please help!
Run alsamixer -c 0 in your console and use the arrow keys to play around with the volumes.
For me: Setting Master to a value where the sound quality was good enough made it very very low. Setting Master to maximum, decreasing PCM to 81 and setting everything else to 0 fixed the problem.
UPDATE: (for Ubuntu 10.10) Click on the volume icon in the upper-right corner, then click on Sound Preferences, and make sure that the Output volume doesn't go above "Unamplified." Then, click on the volume icon again and see where the volume meter is positioned. That is the maximum volume you should set in order to hear a clear sound.
OR: (for Ubuntu 10.10) Click on the volume icon in the upper-right corner, then click on Sound Preferences, set the main volume to 100% and set the volume for each application to a more appropriate level. Each time you open an application that needs to use sound for the first time, you have to do this (because applications that don't currently use sound don't appear in that list).
You currently have to choose between annoying and complicated :(
- 511
i suggest you to use pulseaudio system wide equalizer.
- Ubuntu Lucid User
PPA
sudo add-apt-repository ppa:psyke83/ppa
Then install by typing
sudo apt-get update && sudo apt-get install pulseaudio-equalizer
- Ubuntu Maverick User
You have to install it manually by downloading .deb file below,
Pulse Audio Wide Equalizer ==> for both 32bit and 64bit
- 11
I had exactly the same problem and this is how i made it work
http://ubuntu-ky.ubuntuforums.org/showpost.php?p=10050353&postcount=16 and here is the general link as given in the above link https://help.ubuntu.com/community/HdaIntelSoundHowto
- 2,468
I would look at the mixer first. Right click on the sound icon in the notification area. I use Kubuntu, so am not sure of the exact terminology. It will be at the bottom of the drop down. In Kubuntu it is show mixer window, but it will be similar. Then check the sliders and muted boxes. Uncheck ones that affect your headphone jack and slide the slider farther forward for your master volume.
- 476
There are some solutions for the Intel HDA sound controller on ubuntu community documentation. At the end of the page there is a tip about getting the driver from realtek site.
- 5,083
Intel HDA has a lot of problems. Getting it to work (from what I've seen and experienced) is hit or miss. The kubuntu user is right about your volume mixer, which you may have to configure to show all options (slider controls). For me it was bringing Headphone jack sense into the mixer and enabling it. (It was disabled by default.)
- 302
- 1
- 10
Have you tried fiddling with alsamixer in the terminal? If turning up the volume makes the quality terrible then your PCM values may be way too high.
For these types of problem there are specific steps to follow,
- Obtain the full technical information of your system by following the commands at https://wiki.ubuntu.com/DebuggingSoundProblems and performing the rest of the steps. You can also obtain the information about
alsa-info.sh(see previous URL for more), which will helps us to direct you from here. - Install the latest Alsa packages according to the instructions at https://help.ubuntu.com/community/HdaIntelSoundHowto Then reboot. In this way you will get the latest Alsa code which may include better support for your sound card. This is an easy way to try to fix if you do not want to read much.
- 9,241
If you have windows installed be sure this is not set to mute. I just find out this was the problem, why skype with headphones didnt work. Also set skype, in options, not to adjust the sound, and turn the input sound in sound preferenses to the highest lewel.
