When I click the insall button on PlayOnLinux, the window is too small and it doesn't allow me to stretch it out. Why this is a problem is because it doesn't show the "Install an unlisted program" button. I've done some research but no one else has my problem. It did work fine before but no it doesn't. Edit: The window looks like this
Asked
Active
Viewed 1,606 times
agamer569
- 199
This is only a temporary work around and the problem should be filed as a bug appropriately.
The following line will change the size of the add window in PlayOnLinux. Copy and paste it to a terminal window to change the size:
sudo sed -i 's/windows_add_size = 25/windows_add_size = 75/' /usr/share/playonlinux/python/lib/Variables.py
To undo the changes copy and paste this line:
sudo sed -i 's/windows_add_size = 75/windows_add_size = 25/' /usr/share/playonlinux/python/lib/Variables.py
Hope this helps!
Terrance
- 43,712
