I'm using Ubuntu Mate 16.04 with ThinkPad T450s.
When I login into Ubuntu, keyboard back-light is on, then I turn it off, then after spending idle time when I touch to any key, keyboard back-light turn on again!
What should I do for disable it?
[UPDATE]
I found the keyboard-backlight brightness file path that toggles with three mode:
  • 0 is off
  • 1 is low light
  • 2 is high light
I set the brightness to 0 in rc.local as following, but it not worked:
I put the following line before exit 0 in /etc/rc.local:
  • echo 0 > /sys/class/leds/tpacpi:\:\kbd_backlight/brightness
Thanks in advance.
Benyamin Jafari
  • 4,234
  • 27
  • 37
From https://ubuntu-mate.community/t/keyboard-light-keeps-turning-on-after-login-and-or-unlock/6914/12 I got the right direction for the solution (similar problem with Ubuntu Mate 18.10 on a ThinkPad T480s).
I edited /etc/dbus-1/system.d/org.freedesktop.UPower.conf (with sudoedit) and changed the allow in the lines
<allow send_destination="org.freedesktop.UPower"
       send_interface="org.freedesktop.UPower.KbdBacklight"/>
to a deny so after editing the lines look like this:
<deny send_destination="org.freedesktop.UPower"
No service restart or reload necessary, works directly after changing the file. Manual switching of the keyboard backlight with the hotkey (Fn+Space).
