I am using Ubuntu 18.04 but I cannot open the terminal. when i want to open the terminal i face a notification that is given below . please help me I cannot install any other apps
I solve this problem by installing xterm from software, and running /usr/bin/gnome-terminal. This gave me an error I hadn't seen before, which was that my python installation was not as expected. I fixed the python installation and everything works again.
The python issue was that I was trying to use a python version manager, but gnome-terminal was looking for the binary python3 in /usr/bin. I had disabled that binary by renaming it to old_python3. I renamed it again to python3 and everything worked.
- 257
- 2
- 9
It might be possible that terminal is missing from your system for some reason. You can check that by checking out
/bin/gnome-terminal
You can install it using ubuntu software center. Open the software center and type "terminal" and then install it.
- 193
- 1
- 7
I found the solution for me was to follow the steps from the link below but changing the python version to the 3.6 in my case.
- Try to update your locale
- Try to change your environment variables or reset them to their default values.
- Or just restarting your PC sometimes help
- 1
