It's fairly rare these days, but once in a while I bump into a video that has only one-sided sound (only the left channel or only the right channel.) Is there a way for me to change my audio setup so that one side gets played on both sides?
Note that I do not want to download the video, fix it, and play it then. I'd like to just tweak my settings for that one video so the left channel plays on both sides: left and right; or the right channel plays on both sides: left and right.
Changing the balance doesn't help since there is nothing on the other side, it's not a balance problem.
karel
  • 122,292
  • 133
  • 301
  • 332
Alexis Wilke
  • 2,787
If you are talking about video in the browser such as on youtube then I would recommend a plugin. I use Audio EQ for Chrome and I absolutely love it. It allows me to adjust the gain, EQ and make it mono.
fleshTH
  • 101
Alternatively, system-wide solution using pulse:
  1. Get sink list
    pactl list sinks | grep name:
  2. Use remap module to map channels
    pactl load-module module-remap-sink sink_name=mono \
     master=<sink_from_prev_cmd> channels=2 channel_map=mono,mono
To stop it, Unload the module
pactl unload-module module-remap-sink
For permanent setup, add command from step 2 to /etc/pulse/default.pa
Source: Can I downmix stereo audio to mono?
user.dz
  • 49,176
