10
I am trying to install VMware with the instructions at https://help.ubuntu.com/community/VMware/Player
I get an error that tells me to look into a log file, which contains:
Extracting the vmmon source from "/usr/lib/vmware/modules/source/vmmon.tar".
Successfully extracted the vmmon source.
Building module with command "/usr/bin/make -j4 -C /tmp/modconfig-GoVdrH/vmmon-only auto-build HEADER_DIR=/lib/modules/4.15.0-22-generic/build/include CC=/usr/bin/gcc IS_GCC_3=no"
Failed to build vmmon.  Failed to execute the build command.
To figure out what was wrong exactly, I ran vmware-modconfig --console --install-all on the command line, and it revealed these errors:
./arch/x86/include/asm/processor-flags.h:39:0: note: this is the location of the previous definition
 #define CR3_PCID_MASK 0xFFFull
/tmp/modconfig-3S1CBa/vmmon-only/linux/driver.c:256:12: error: ‘struct timer_list’ has no member named ‘data’
    tscTimer.data     = 0;
    unsigned int lockedPages = global_page_state(NR_PAGETABLE) +
                               global_numa_state
/tmp/modconfig-3S1CBa/vmmon-only/linux/driver.c: In function ‘init_module’:
/tmp/modconfig-3S1CBa/vmmon-only/linux/driver.c:338:4: error: implicit declaration of function ‘init_timer’; did you mean ‘init_timers’? [-Werror=implicit-function-declaration]
    init_timer(&tscTimer);
    init_timers
/tmp/modconfig-3S1CBa/vmmon-only/linux/hostif.c: In function ‘HostIF_InitUptime’:
    init_timers
/tmp/modconfig-3S1CBa/vmmon-only/linux/hostif.c:1754:31: error: assignment from incompatible pointer type [-Werror=incompatible-pointer-types]
    uptimeState.timer.function = HostIFUptimeResyncMono;
 LinuxDriverSyncReadTSCs(uint64 *delta) // OUT: TSC max - TSC min
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target '/tmp/modconfig-3S1CBa/vmmon-only/linux/hostif.o' failed
make[2]: *** [/tmp/modconfig-3S1CBa/vmmon-only/linux/hostif.o] Error 1
Makefile:110: recipe for target 'vmmon.ko' failed
make: *** [vmmon.ko] Error 2
How to fix it, or make implicit-function-declaration and incompatible-pointer-types be not considered as errros?
Or any easier method to install the latest VMware on 18.04?
Note: Different error from VMWare Workstation Pro 12 on Ubuntu 16.04 cannot compile vmmon
Nicolas Raoul
  • 11,921
I found a solution and create a script file based on mkucebek's github sources .
You must create a file with this content and run it each time it's needed (Usually when you install a new kernel) :
#!/bin/bash
VMWARE_VERSION=workstation-12.5.9
TMP_FOLDER=/tmp/patch-vmware
rm -fdr $TMP_FOLDER
mkdir -p $TMP_FOLDER
cd $TMP_FOLDER
git clone https://github.com/mkubecek/vmware-host-modules.git
cd $TMP_FOLDER/vmware-host-modules
git checkout $VMWARE_VERSION
git fetch
make
sudo make install
sudo rm /usr/lib/vmware/lib/libz.so.1/libz.so.1
sudo ln -s /lib/x86_64-linux-gnu/libz.so.1
sudo /etc/init.d/vmware restart
Then, you just have to launch VMware Workstation without building modules.
abu_bua
  • 11,313
Charly
  • 241
Install the latest version 14.1.2. The bug has been fixed. See here. Here is the download link.
Michael
  • 533
#!/bin/bash
VMWARE_VERSION=`vmware-installer -l |grep workstat|awk '{print $2}' |awk 'BEGIN {FS="."}{print "workstation-"$1"."$2"."$3}'`
echo $VMWARE_VERSION
rm -fdr $TMP_FOLDER
cd $TMP_FOLDER
git fetch
make
sudo make install
This works for my on Fedora 30 and Workstation 15.1.0
