I created a Live USB with Ubunbtu 18.04 on it so I can look into dual booting on a Windows 10 PC.
When I boot Ubuntu from USB, I can't get my wireless keyboards to work. They both work on Windows, so there is no battery issue. They both use a wireless USB dongle. The wireless mouse with one of them works fine.
I used a wired keyboard to install xserver-xorg-input-all using sudo apt-get install xserver-xorg-input-all, but the wireless keyboards still won't work
Is there anything else anyone can suggest that I try ?
Edit:
Output from lsusb is as follows -
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0781:556b SanDisk Corp.
Bus 001 Device 009: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 007: ID 17ef:60a9 Lenovo
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 006: ID 0bda:0821 Realtek Semiconductor Corp.
Bus 001 Device 008: ID 046e:550f Behavior Tech. Computer Corp.
Bus 001 Device 004: ID 046e:5411 Behavior Tech. Computer Corp.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
The SanDisk device is the Live Usb and Lenovo is the keyboard/mouse. The keyboard/mouse are as supplied with the PC and are Lenovo. My alternative set with the same symptoms is by Microsoft.
Update January 2, 2022
This bug has been fixed according to the bug report: Lenovo Essential Wireless Keyboard doesn't works (Primax Electronics manufacturer) #36 which states:
Julian Alarcon (julian-alarcon) wrote on 2019-09-19: #36
This is finally fixed! I test it in Ubuntu 18.04 kernel: 4.15.0-64, Ubuntu 18.04.3 kernel: 5.0.0-29.
The keyboard and mouse seems to work fine with no issues! I had to disable a workaround used to make it work! https://github.com/y-trudeau/linux_lenovo_ultraslim_plus
Original post
The original post is shown below for historical purposes.
Extensive history to this problem
You are not alone. Someone in Ubuntu forums has reported:
Re: Lenovo Essential Wireless Keyboard and Mouse Combo doesn't work
I just reported this bug: Lenovo Essential Wireless Keyboard doesn't works (Primax Electronics manufacturer)
The bug is still present in the latest Ubuntu version (18.04 bionic beaver) with stable kernel.
It's also reported by people from Linux Mint, Fedora and others.
Possible workarounds
Although the bug has been confirmed by the Ubuntu Team, no one has been assigned to fixing it yet. In the meantime there are two workarounds:
If you tried the Lenovo fix from WinEunuuchs2Unix's answer and it did not work, you might want to try this modified fix that I made for another Primax (HP brand) wireless keyboard + mouse combo with similar problems:
https://github.com/JohnJohanssonChalmers/hp_wireless_keyboard
I have seen several reports of these types of problems with Primax keyboards that could not be solved with the Lenovo fix. I suspect that my modified fix might also wok for some non-HP keyboards.
jkej
  • 141
