I have Ubuntu 18.0 LTS, I have a internal harddisk of 1 TB but the problem is I am not able to copy or remove anything from it, I checked several questions similar to this but none of them worked. All of them try to change permission of files which I guess does not address my issue. As of now I have tried out these commands and here are their outputs, I am new to linux so please I need detailed answers.
The hard disk is on /dev/sda1
vi /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name
devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb5 during installation
UUID=fe33f56a-d8bc-49d1-bee9-256510fbbc66 /               ext4
errors=remount-ro 0       1
/swapfile                                 none            swap    sw
0       0
why I think the file permissions are not a issue is this:
ls -l /media/ace
total 16
drwxrwxrwx 1 ace ace 8192 May 10 19:44  EE9480699480365D
drwxrwxrwx 1 ace ace 4096 May  8 09:23 'New Volume'
drwxrwxrwx 1 ace ace 4096 May 10 06:58 'New Volume1'
Well trying out chmod gives this
chmod 775 'New Volume'
chmod: changing permissions of 'New Volume': Read-only file system
Please help me I require the hard disk space. Cause I am now using the hard disk in which ubuntu is present and I am worried I might run into trouble.
here's the output of
lsblk -fmi | grep -v loop
> NAME   FSTYPE   LABEL           UUID                                 MOUNTPOINT                      SIZE OWNER GROUP MODE
`sda        931.5G root  disk  brw-rw----
-sda1 ntfs     New Volume      508C46638C4643A6                     /media/ace/New Volume         931.5G root  disk  brw-rw----
sdb        232.9G root  disk  brw-rw----
|-sdb1 ntfs     System Reserved 942A05572A0537AE                                                     549M root  disk  brw-rw----
|-sdb2 ntfs                     EE9480699480365D                     /media/ace/EE9480699480365D    58.1G root  disk  brw-rw----
|-sdb3 ntfs     New Volume      AC201B65201B35B4                     /media/ace/New Volume1        115.7G root  disk  brw-rw----
|-sdb4        1K root  disk  brw-rw----
-sdb5 ext4                     fe33f56a-d8bc-49d1-bee9-256510fbbc66 /                              58.6G root  disk  brw-rw----`
sudo fsck -tntfs /dev/sda1 O/P:fsck from util-linux 2.31.1
nothing else happened even after reboot I tried the command you gave as well
Your filesysystem is mounted read-only. Any write attempt will fail. You need to mount the filesystem in write mode, but first, determine why the filesystem is read-only -- the most likely explanation is that there are errors on it. Run
sudo fsck -text4 /dev/sdb5
That should fix the errors, and allow a reboot to mount the filesystem in write mode, fixing your problem.
ubfan1
  • 19,049
A real full shutdown of Windows allows the ntfs partitions to be mounted with R/W perms by Ubuntu. For a full shutdown of windows, hold the SHIFT key as you press the "Shut down" button. You may also disable the 'fast boot' in the windows power control panel.
If you plan to use the 1Tb drive with Ubuntu, you may backup and format the drive with ext4 filesystem. This will give you all the linux security features but the drive wont be readable by windows.
cmak.fr
  • 8,976
