I want to ‘lockdown’ a particular key/value combination in dconf, so that only superusers will be able to modify that particular setting. In order to achieve this it is necessary to add a ‘lock’ to the system database, so that no equivalent key/value listed in a higher order database (in the dconf profile) can take precedence.
For a detailed explanation of the concept of a dconf profile and the related ‘key files’ please see the Gnome System Administrators Wiki.
From the System Admin Wiki:
Lockdown is supported by creating a 'locks' subdirectory in the key file directory (ie: /etc/dconf/db/local.d/locks). The files contained in this directory contain a list of keys to lock, one per line.
My keyfile directory shows as ‘ibus.d’, as opposed to ‘local.d’ given in the example:
:/etc/dconf/db/ibus.d$
By checking the dconf profile /etc/dconf/profile/ibus, this would appear correct:
Contents of 'ibus' file: user-db:user \ system-db:ibus
As per the Wiki:
Create an appropriate key file:
==> /etc/dconf/db/ibus.d/00-media-handling ==<[org/gnome/desktop/media-handling]automount=falseCreate a ‘locks’ subdirectory and add an appropriate file:
==> /etc/dconf/db/ibus.d/locks/00_media-handling-lock ==</org/gnome/desktop/media-handling/automount
In my case I have set, and locked, the automount key, for the org.gnome.desktop.media-handling schema, to 'false'.
Finally run sudo dconf update. For good measure I also reboot the machine.
The expected behaviour, upon attaching a USB drive, would be for the device not to automount. This, however, is not the case. If I attach a USB drive and run df:
/dev/sdb1 983344 192 983152 1% /media/user/xxxx-xxxx
Assuming I am at fault; I have started from ‘scratch’ numerous times, each time following the (identical) instructions from varied sources, including examples given on this site; example one and two. Each time to no avail. Please could you kindly enlighten as to where I could be going wrong? (Ubuntu 16.04)
