I currently dual booting between Ubuntu and Windows 10. However, whenever I try to boot from Windows 10 in grub it simply restarts and brings me right back to grub again.
I used boot-repair to create a pastebin:
http://paste.ubuntu.com/p/pzJqP55FVV/
It's too long to paste it here.
But I have no idea what anything in the pastebin really means or how to fix grub. I have tried updating grub but the same problem occurs.
I ran sudo ntfsfix -b -d /dev/sda1 and got
Mounting volume... Failed to load runlist for $MFT/$DATA.
highest_vcn = 0x32cfb, last_vcn - 1 = 0x4027f
Failed to load $MFT: Input/output error
FAILED
Attempting to correct errors... Failed to load runlist for $MFT/$DATA.
FAILED
Failed to startup volume: Input/output error
Checking for self-located MFT segment... OK
Volume is corrupt. You should run chkdsk.
karel
  • 122,292
  • 133
  • 301
  • 332
Attempt to repair the NTFS drive from linux. Per this solution, do the following:
Install ntfs-3g with sudo apt-get install ntfs-3g . Then run the ntfsfix command on your NTFS partition
sudo ntfsfix -b -d /dev/sdaX
if ntfsfix won't or can't fix your drive, you will have to run chkdsk from windows. You can boot from Hiren's miniXP boot disk and use the command line there to run chkdsk.
