I am using Ubuntu 18.04 on Dell XPS-13 and every time the laptop starts bluetooth is enabled and you have to disable it manual. But i am using it not very often.
Therefore: is it possible to have bluetooth disabled by default? (i know about the tweak in the rc.local file but since Ubuntu 14.04 the rc.local does not exist and is not used anymore)
J.Doe
  • 93
gedit /etc/bluetooth/main.conf
and set this:
AutoEnable = false
A more radical way is to either stop the bluetooth service
sudo systemctl stop bluetooth.service
Or even more radical is to disable it permantly
sudo systemctl disable bluetooth
solsTiCe
  • 9,515
Rinzwind
  • 309,379
Here is how you can create a script that will run on startup and perform an action to kill the Bluetooth service, and that would be the following (I use nano, feel free to use any other text editor):
Step 1: Navigate to the folder:
cd /etc/systemd/system/
Step 2: First create a script that will kill the Bluetooth service once run:
nano bluetoothkill.sh
Step 3: Enter the following code, save and exit:
#!/bin/bash
rfkill block bluetooth
exit 0
Step 4: Create a foo.service file in the same folder /etc/systemd/system/ :
nano foo.service
Step 5: Enter the following code, save and exit:
[Unit]
Details=Additional startup scripts
After=network.target
[Service]
ExecStart=/etc/systemd/system/bluetoothkill.sh
[Install]
WantedBy=default.target
Step 6: Run the following command in the terminal:
sudo chmod 744 bluetoothkill.sh
Step 7: Run the following command in the terminal:
sudo systemctl start foo.service
Step 8: Restart the machine and on the next boot you will notice that the Bluetooth service is no longer enabled by default on startup. You can still enable it when ever you like in the settings, or the terminal it is behaving without any errors.
If you like to add more scripts on startup, you can always edit the foo.service file and add additional lines under the [Service] bracket to run additional scripts on startup, for example:
ExecStart=/full-script-filepath/newscript.sh
laslozr
  • 53
