Any use of dislocker returns this error:
dislocker: error while loading shared libraries: libmbedcrypto.so.0:
cannot open shared object file: No such file or directory
How to fix it?
How to fix it?
I have finally did it.
Steps to get it to work:
add /usr/lib/x86_64-linux-gnu/ to LD_LIBRARY_PATH:
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/x86_64-linux-gnu/ export LD_LIBRARY_PATH
in /usr/lib/x86_64-linux-gnu/ i have libmbedcrypto.so.2.8.0 so i had to create symlink as mentioned before by Elder
/usr/lib/x86_64-linux-gnu$ sudo ln -sf libmbedcrypto.so.2.8.0 libmbedcrypto.so.0
after doing that there was also a problem with libruby-2.3.so.2.3. Doing another symlink solved that problem to:
sudo ln -sf libruby-2.5.so.2.5 libruby-2.3.so.2.3
After that dislocker is finally working and i can decrypt my windows bitlocker encrypted drives.
libmbedcrypto.so is contained within the libmbedtls-dev package in the universe repository.
First enable the universe repository if it isn't already.
Then issue the command sudo apt install libmbedtls-dev
You might need to create a softlink called libmbedcrypto.so.0 linking to libmbedcrypto.so as mentioned here.
Note: I haven't personally tested this approach but logically it would seem worth a try.
