I'm using Precise (development version), which means I'm very much expecting to see bugs. However, this time, it's fairly important that I find a workaround quickly – and it is a general question.
The problem: When I open Sound Settings from the audio menu or from Gnome Control Center, it simply closes with no question of bug reports. I am too drunk to look at stack traces, and I really want to listen to Nellie McKay – loudly. Now, I have a USB audio device that's connected to my speakers. It has no headphone output. I would like to change the output device to my internal audio source – which does have headphone output – so that I can listen to music without bothering the neighbors. For some reason or other, I can't open the audio dialog.
Since PulseAudio seems to be working properly, I need a CLI-way to change the audio device that's used for output for PulseAudio sources.
If someone can tell me how to do this, I'd be very happy. If I get the explanation before I'm evicted for public disturbance, I'll consider that a bonus. :)
You might find your solution here:
Audio output device, fast switch?
or here:
How to change pulseaudio sink with "pacmd set-default-sink" during playback?
Subbeh
  • 206
An alternative way that does not use the Control center is to use the sound switcher indicator (webup8 article).
gioele
  • 406
