I have seen and used the GUI hex-editor bless, to modify bitmaps to match a separate file type (form bmp to srf). My question is how to modify file headers programmatically with the command line. What programs would allow me to make changes to file headers from shell script?
I have looked in synaptic package manager, but I'm new to modifying files in hex. Do bitmaps count as binary files? Where this is a software recommendation request, an acceptable answer would allow me to write, overwrite, or change specific values to specific locations (such as the first 16 bytes of a file), in the command line.
dessert
  • 40,956
j0h
  • 15,365
xxd is a very powerful command-line hex editor which allows you to change binary files with a single command line. You can use it this way:
xxd -r -p -o OFFSET <(echo NEW HEX SIGNATURE) FILE  # or
echo NEW HEX SIGNATURE | xxd -r -p -o OFFSET - FILE
Let's “convert” 01.png file to rar format (hex signature 5261 7221 1A07 0000, offset 01):
01.png: PNG image data, 1280 x 1024, 8-bit/color RGB, non-interlaced
$ xxd 01.png | head -1
00000000: 8950 4e47 0d0a 1a0a 0000 000d 4948 4452  .PNG........IHDR
01.png: RAR archive data, vdb, os: MS-DOS
00000000: 5261 7221 1a07 0000 0000 000d 4948 4452  Rar!........IHDR
See man xxd for other useful options and lots of helpful examples.
1If the offset is 0 the option -o can be omitted, I include it here only to show its usage.
If you like it better you can do the truncating with dd as well, but that seems unnecessarily complicated:
dd conv=notrunc obs=1 if=<(xxd -r -p -o 0 <(echo 5261 7221 1A07 0000)) of=01.png
Further reading (besides usual command-line help):
dessert
  • 40,956
