I was making some changes to the system language and keyboard input language and I was asked to restart to apply the changes. When it had restarted, I tried to type my password and it was always incorrect. Then I discovered that I was typing my password in Arabic but my password is in English.
The question here: How can I change the keyboard language when I am typing the password?
Melebius
  • 11,750
option 1:
In the bar at the top of your screen, you should see a small box (probably white with a letter in it) select that and you should get a drop down for language selection. Select English.
option 2:
you may have a small circle with a man in it in the top bar. If so select that and select onscreen keyboard.
option 3:
Boot into safe mode and set the language in there to English and then reboot.
option 4:
Reset password in safe mode How do I reset a lost administrative password?
After you login you should set up a keyboard shortcut to change the language of your keyboard How to switch language keyboard combination?
Jeff
  • 1,724
