Since I updated Ubuntu from 16.x to 17.10 and then to 18.04 I don't have any sound. There is also a problem with videos in web browser (they look like a slideshow, still no sound) and Spotify, where it looks like music is loading but nothing happens.
Asked
Active
Viewed 6,292 times
Have you tried re-installing pulseaudio and alsa? If not, type these commands in order.
sudo apt update
sudo apt remove --purge alsa-base pulseaudio
sudo apt install alsa-base pulseaudio
sudo alsa force-reload
EDIT : For users with older versions of Ubuntu where apt is not there, use apt-get.
Vishesh Gautam
- 768
- 3
- 14
I came here from question
Spotify mutes itself on Ubuntu 18.04
which btw I don't think is duplicate of this but it is now closed as duplicate. So I write my answer here - the problem was actually caused by Teamspeak client that muted Spotify. When I turned of TS, Spotify didn't mute itself.
I found the way how to solve this issue here
https://forum.teamspeak.com/threads/138336-TeamSpeak-mutes-Spotify
You should check if
/etc/pulse/default.pa
contains following line
load-module module-role-cork
In case it does delete that line and restart Pulseaudio.
Miroslav
- 271
