Trying to connect to tigervnc server running on Ubuntu 18.04 (using TigerVNC viewer windows client). After the initial authentication, I get an additional authentication prompt that reads "Authentication is required to create a color pr...". This happens only for the first login following a tigervnc server restart. Is there anyway I can bypass this?
Asked
Active
Viewed 1.3k times
I fixed this by creating this file and setting perms to 644, and owner root:root:
Filename: /etc/polkit-1/localauthority.conf.d/02-allow-colord.conf
Contents:
polkit.addRule(function(action, subject) {
if ((action.id == "org.freedesktop.color-manager.create-device" ||
action.id == "org.freedesktop.color-manager.create-profile" ||
action.id == "org.freedesktop.color-manager.delete-device" ||
action.id == "org.freedesktop.color-manager.delete-profile" ||
action.id == "org.freedesktop.color-manager.modify-device" ||
action.id == "org.freedesktop.color-manager.modify-profile"
subject.isInGroup("{nogroup}")
return polkit.Result.YES;
wryan
- 189
Let me just extract the concrete fix for 18.04 only from the sequel to this excellent blog post. The latter drills down to the root cause of this issue; the former fixes it properly — while avoiding a crash caused by the return polkit.Result.YES; solution already posted here and elsewhere.
cat << EOF | sudo tee /etc/polkit-1/localauthority/50-local.d/45-allow-colord.pkla
[Allow Colord all Users]
Identity=unix-user:*
Action=org.freedesktop.color-manager.create-device;org.freedesktop.color-manager.create-profile;org.freedesktop.color-manager.delete-device;org.freedesktop.color-manager.delete-profile;org.freedesktop.color-manager.modify-device;org.freedesktop.color-manager.modify-profile
ResultAny=no
ResultInactive=no
ResultActive=yes
EOF
This is relevant only for PolKit < 0.106 (pkaction --version).
For PolKit 0.106+ (Ubuntu 18.10+) this authorization is granted differently, via the javascript .conf file:
cat << EOF | sudo tee /etc/polkit-1/localauthority.conf.d/02-allow-colord.conf
//-- no group restriction; allow any user to manipulate color profiles!
//-- uncomment and substitude adm with the group you need, if needed.
// subject.isInGroup("{adm}")
EOF
ulidtko
- 5,988
