I'm on 18.04 in a Asus Zenbook laptop and my sound works fine after a shutdown (clean slate). If I boot into ubuntu, sound works, if i reboot still into ubuntu, sound still works. If I boot into Windows 10 and then shut down and boot into ubuntu, sound works. But if I boot into windows 10 and then reboot into ubuntu, now the sound doesn't work (nothing is muted in alsamixer but there is no sound at all). Only a shutdown fixes it, reboots don't.
I already disabled fast boot in windows and killed/cleaned pulse audio as suggested in all these other answers. Sound doesn't work on headphones either
I took two syslog snapshots when sound works and when it doesn't and I don't see any significant differences between them. It really looks to me like a hardware/firmware issue but I imagine there must be a way to fix it from software. Any suggestions?
hilikus@developorium:~$ grep -C 3 snd no-sound-after-reboot
May 5 developorium kernel: [ 3.229033] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
May 5 developorium kernel: [ 3.232083] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
May 5 developorium kernel: [ 3.232086] cfg80211: failed to load regulatory.db
May 5 developorium kernel: [ 3.235334] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
May 5 developorium kernel: [ 3.235547] uvcvideo: Found UVC 1.00 device USB2.0 HD UVC WebCam (13d3:5694)
May 5 developorium kernel: [ 3.244124] uvcvideo 1-6:1.0: Entity type for entity Realtek Extended Controls Unit was not initialized!
May 5 developorium kernel: [ 3.244126] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
May 5 developorium kernel: [ 3.416112] thermal thermal_zone6: failed to read out thermal zone (-61)
May 5 developorium kernel: [ 3.417112] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
May 5 developorium kernel: [ 3.804303] [drm] RC6 on
May 5 developorium kernel: [ 3.832374] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
May 5 developorium kernel: [ 3.861595] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
May 5 developorium kernel: [ 3.861597] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
May 5 developorium kernel: [ 3.861598] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
May 5 developorium kernel: [ 3.861599] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
May 5 developorium kernel: [ 3.861600] snd_hda_codec_realtek hdaudioC0D0: inputs:
May 5 developorium kernel: [ 3.861601] snd_hda_codec_realtek hdaudioC0D0: Mic=0x12
May 5 developorium kernel: [ 3.915132] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
May 5 developorium kernel: [ 3.915169] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
May 5 developorium kernel: [ 3.915200] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
