I upgraded to Ubuntu 18.04 and sound disappeared and showed the infamous "Dummy Output", I thought the problem was with alsa and pulseaudio so I removed them and reinstalled them but that did not fix it. I tried the command aplay -l The output was : aplay: device_list:270: no soundcards found.. I tried lspci and the output was:
00:00.0 Host bridge: Intel Corporation Skylake Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 520 (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Network controller: Intel Corporation Wireless 3160 (rev 83)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 07)
As you can see without Audio device.
I ran the alsa-info script https://gist.github.com/craftyjon/902247 and This was the output:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.64
> !!Script ran on: Sat May  5 14:11:34 UTC 2018
> !!Linux Distribution
> Ubuntu 18.04 LTS \n \l DISTRIB_ID=Ubuntu DISTRIB_DESCRIPTION="Ubuntu 18.04 LTS" NAME="Ubuntu" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 18.04 LTS" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=bionic
> !!DMI Information
> Manufacturer:      Dell Inc.
Product Name:      Inspiron 5559
Product Version:
Firmware Version:  1.1.6
Board Vendor:      Dell Inc.
Board Name:        04D1V1
> !!ACPI Device Status Information
> /sys/bus/acpi/devices/ACPI0003:00/status   15
/sys/bus/acpi/devices/ACPI000C:00/status     15
/sys/bus/acpi/devices/DELLABCE:00/status     15
/sys/bus/acpi/devices/DLLC6B2:00/status      15
/sys/bus/acpi/devices/DLLK06B2:00/status     15
/sys/bus/acpi/devices/INT33A1:00/status      15
/sys/bus/acpi/devices/INT33D0:00/status      15
/sys/bus/acpi/devices/INT340E:00/status      15
/sys/bus/acpi/devices/INT344B:00/status      15
/sys/bus/acpi/devices/INT3F0D:00/status      15
/sys/bus/acpi/devices/LNXPOWER:00/status     1
/sys/bus/acpi/devices/LNXPOWER:01/status     1
/sys/bus/acpi/devices/LNXPOWER:02/status     1
/sys/bus/acpi/devices/PNP0103:00/status      15
/sys/bus/acpi/devices/PNP0C02:03/status      3
/sys/bus/acpi/devices/PNP0C02:04/status      3
/sys/bus/acpi/devices/PNP0C09:00/status      15
/sys/bus/acpi/devices/PNP0C0A:00/status      31
/sys/bus/acpi/devices/PNP0C0F:00/status      9
/sys/bus/acpi/devices/PNP0C0F:01/status      9
/sys/bus/acpi/devices/PNP0C0F:02/status      9
/sys/bus/acpi/devices/PNP0C0F:03/status      9
/sys/bus/acpi/devices/PNP0C0F:04/status      9
/sys/bus/acpi/devices/PNP0C0F:05/status      9
/sys/bus/acpi/devices/PNP0C0F:06/status      9
/sys/bus/acpi/devices/PNP0C0F:07/status      9
/sys/bus/acpi/devices/device:4e/status   15
/sys/bus/acpi/devices/device:4f/status   15
/sys/bus/acpi/devices/device:53/status   15
/sys/bus/acpi/devices/device:66/status   11
> !!Kernel Information
> Kernel release:    4.15.0-20-generic
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         x86_64
SMP Enabled:       Yes
> !!ALSA Version
> Driver version:
Library version:    1.1.3
Utilities version:  1.1.3
> !!Loaded ALSA modules
> !!Sound Servers on this system
> Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
> !!Soundcards recognised by ALSA
> !!PCI Soundcards installed in the system
> !!Advanced information - PCI Vendor/Device/Subsystem ID's
> !!Modprobe options (Sound related)
> snd_pcsp: index=-2
> snd_usb_audio: index=-2
> snd_atiixp_modem: index=-2
> snd_intel8x0m: index=-2
> snd_via82xx_modem: index=-2
> snd_usb_caiaq: index=-2
> snd_usb_ua101: index=-2
> snd_usb_us122l: index=-2
> snd_usb_usx2y: index=-2
> snd_cmipci: mpu_port=0x330 fm_port=0x388
> snd_pcsp: index=-2
> snd_hda_intel: jackpoll_ms=500
> !!Loaded sound module options
> !!ALSA Device nodes
> crw-rw----+ 1 root audio 116,  1 May  5 15:58 /dev/snd/seq
> crw-rw----+ 1 root audio 116, 33 May  5 15:58 /dev/snd/timer
> !!Aplay/Arecord output
> APLAY
> aplay: device_list:270: no soundcards found...
> ARECORD
> arecord: device_list:270: no soundcards found...
> !!Amixer output
> !!Alsactl output
> --startcollapse--
> --endcollapse--
> !!All Loaded Modules
> Module
ccm
vmw_vsock_vmci_transport
vsock
vmw_vmci
cmac
bnep
nls_iso8859_1
rtsx_usb_ms
memstick
uvcvideo
videobuf2_vmalloc
videobuf2_memops
videobuf2_v4l2
videobuf2_core
videodev
media
btusb
btrtl
btbcm
btintel
bluetooth
ecdh_generic
arc4
iwlmvm
mac80211
hid_multitouch
dell_laptop
dell_smbios_smm
dcdbas
dell_smm_hwmon
intel_rapl
x86_pkg_temp_thermal
intel_powerclamp
coretemp
kvm_intel
kvm
irqbypass
crct10dif_pclmul
crc32_pclmul
ghash_clmulni_intel
pcbc
aesni_intel
aes_x86_64
crypto_simd
glue_helper
cryptd
intel_cstate
iwlwifi
intel_rapl_perf
cfg80211
joydev
dell_wmi
input_leds
dell_smbios_wmi
dell_smbios
serio_raw
sparse_keymap
dell_wmi_descriptor
wmi_bmof
acpi_pad
idma64
virt_dma
shpchp
mei_me
intel_pch_thermal
mei
intel_lpss_pci
intel_lpss
dell_rbtn
mac_hid
sch_fq_codel
parport_pc
ppdev
lp
parport
ip_tables
x_tables
autofs4
rtsx_usb_sdmmc
rtsx_usb
i915
i2c_algo_bit
drm_kms_helper
syscopyarea
sysfillrect
sysimgblt
psmouse
fb_sys_fops
r8169
ahci
drm
mii
libahci
i2c_hid
wmi
hid
video
pinctrl_sunrisepoint
> !!ALSA/HDA dmesg
I have dealt with sounds problems many times before but at least each time the card was detected by lspci command I don't know if that is a hardware problem.
UPDATE:
I restored the default BIOS settings and the soundcard is visible now. The problem now is that in pavucontrol, the option "Analog Stereo Duplex" and "Analog stereo Input/Output" for that matter are missing. I reinstalled pulseaudio and alsa but it did not work.
Is your sound device blocked by some other processes? fuser should list the pulseaudio command only:
~$ sudo fuser -v /dev/snd/*
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  justme     2067 F.... pulseaudio
/dev/snd/controlC1:  justme     2067 F.... pulseaudio
/dev/snd/pcmC1D3p:   justme     2067 F...m pulseaudio
If you see anything else than pulseaudio as the assigned command, try to get rid of and restart pulseaudio like pulseaudio -k (as user, not root). Afterwards pavucontrol should list your device again ...
I had a similar problems with USB card (Asus Xonar U7) on Ubuntu 18.04
I solved it using instructions from this answer https://askubuntu.com/a/1104763/354702 by João Pimentel Ferreira
1) Remove the ALSA packages.
sudo apt-get --purge remove linux-sound-base alsa-base alsa-utils
2) Reinstall the same packages.
sudo apt-get install linux-sound-base alsa-base alsa-utils
3) Install further audio addon packages
sudo apt-get install dkms build-essential linux-headers-`uname -r`
alsa-base alsa-firmware-loaders alsa-oss alsa-source alsa-tools
alsa-tools-gui alsa-utils alsamixergui
4) Be sure to add the user to group audio
sudo usermod -a -G audio username
5) reboot
sudo reboot
momsab
