My machine config:
Threadripper 1950x 16-core + Gigabyte X399 aorus 7
32GB DDR4
Samsung NVME 960 512GB
UEFI mode with GPT partition scheme
Windows 10 Pro + Ubuntu Server 18.04 LTS
I previously had Windows 10 + Ubuntu 16.04 Server as dual boot and I never had any problems.
What I did so far:
1) I Installed Windows 10 x64 Pro (1803) on my machine - no problems
2) I tried to install Ubtunu 18.04 Server as dual boot but it did not detect existing windows OS. Tried multiple boots but no luck so finally installed Ubuntu causing windows wiped out
3) Then I installed Windows 10 (as dual boot) without disturbing Ubuntu partitions. No problems
4) Now only windows 10 boots so I followed How can I repair grub? (How to get Ubuntu back after installing Windows?) and fixed the issue but now Only Ubuntu boots
5) Then I followed GRUB does not detect Windows but it STILL does NOT detect Windows 10 OS but I can mount the windows partition on Ubuntu. os-prober also sees the Windows OS but grub doesn't! Please see below and advise, Many thanks!
root@ubuntu18:~# mkdir -p /media/windows
root@ubuntu18:~#  fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 01BADB0F-4C8E-4332-BA18-822F08CE451B
Device             Start       End   Sectors   Size Type
/dev/nvme0n1p1      2048   1050623   1048576   512M EFI System
/dev/nvme0n1p2   1050624 361760767 360710144   172G Linux filesystem
/dev/nvme0n1p3 361760768 370149375   8388608     4G Linux swap
/dev/nvme0n1p4 370149376 370182143     32768    16M Microsoft reserved
/dev/nvme0n1p5 370182144 976773119 606590976 289.3G Microsoft basic data
root@ubuntu18:~#
root@ubuntu18:~# mount -t ntfs-3g /dev/nvme0n1p5 /media/windows/
root@ubuntu18:~# os-prober
/dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
root@ubuntu18:~# update-grub
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-4.15.0-20-generic
Found initrd image: /boot/initrd.img-4.15.0-20-generic
Adding boot menu entry for EFI firmware configuration
done
root@ubuntu18:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev             16G     0   16G   0% /dev
tmpfs           3.2G  1.6M  3.2G   1% /run
/dev/nvme0n1p2  169G  1.7G  158G   2% /
tmpfs            16G     0   16G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs            16G     0   16G   0% /sys/fs/cgroup
/dev/loop0       87M   87M     0 100% /snap/core/4486
/dev/nvme0n1p1  511M   29M  483M   6% /boot/efi
tmpfs           3.2G     0  3.2G   0% /run/user/0
/dev/nvme0n1p5  290G  187G  104G  65% /media/windows
but no luck, Please advise.
Amith KK
  • 13,547
Bateman
I think this must be a bug of 18.04.
1) I rebuilt my machine from scratch with WIndows 10 (clean) - No problems.
2) I installed Ubuntu Server 16.04 as dual boot - every thing worked straight forward. Detected windows 10 and grub setup was done and dual boot working fine.
3) I installed Ubuntu Server 17.10 on top of same Ubuntu partitions (not upgrade) alongwith dual boot of same WIndows 10 - No problems - worked straight forward.
4) Please note both #2 & #3 - I have tried with windows settings of Fast boot off & on. Irrespective of this setting, I was able to install both Ubuntu versions (16.x & 17.x) without any problems
5) But Ubuntu 18.04 doesn't even see the Windows partition and/or Windows 10 OS while installing it. It simply overwrites it (even though I chose manual partitioning). Please see below screenshot
Screenshot of ubuntu 18.04 installation
6) As I needed to run 18.04 - I freshly installed 17.10 and did a "do-release-upgrade" and it upgraded to 18.04 without any problems. All good now.
7) If anyone could please reproduce this issue(with similar setup) and report, it would be great, Many thanks!!
Bateman
